New AC compressor
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by grayfox, Aug 12, 2025.
  1. grayfox
    grayfox Junior Member
    Wisconsin
    I have a 2012 Prius C - ~ 158k miles. The AC stopped working at some point (maybe a few months ago?) I live in the midwest and don't use the AC much but this summer has gotten quite hot lately. I don't drive far for work (~2 mi one way) - I average about 600 mi/month.
    I was told I need a new compressor. Estimate $2500+ (independent place).
    I do love my car which I paid for in full 5 years ago. I really don't want a monthly car payment, but I worry about putting that kind of money into a 13-14 YO car. I am leaning towards doing the fix and keeping the car. Should I be convinced otherwise?
    Could I even trade the car in with the AC broken?
  2. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    Trade-in is fine. That's how most people make their problems go away lately. No shame in it, and to be honest there isn't even that much of a financial penalty vs. the alternatives.
    The car obviously has life left in it but at this age it is going to start having expensive problems more frequently.
    The most obvious solution I can think of for this situation is to pay an independent mechanic to install a used compressor from a crashed Prius. That should be considerably cheaper. A quick search on car-part.com shows a bunch in Wisconsin under $100 each.
    At the very least, shop around, get a 2nd opinion from another mechanic etc. You don't really even need a full-service mechanic, you could also talk to automotive A/C specialists.
    Good luck!
    EDIT: adding-
    Think about what killed your current compressor. Sometimes it's obvious- you hit some road debris or there was a frontal collision etc. But if that didn't happen, the next most common cause of failure is that it worked itself to death in response to low refrigerant levels: a system leak. Because the HVAC is automatic, the thing will always try to compensate for variable conditions, right up to the point where it wears itself out.
    So be suspicious and look for leaks unless you can explain the failure more directly. You don't want to have to do this again soon.
    #2 Leadfoot J. McCoalroller, Aug 13, 2025
  3. grayfox
    Wisconsin
    I have no idea what would have caused it. I get my car checked every 6 months - AC is checked every time. It was fine on this past Dec's report; June is when they marked it as not working. If I could find a newer C, any years I should avoid? (I really like the small size.)
  4. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    There were remarkably few changes in the production run for the US-export version of the c.
    I know what you man about the size. Hard to find anything like that these days.
    For my money the 2018-2019 final versions are the very best, but there are no bad years from a reliability standpoint. In that final version you get the really nice LED headlights and the early version of the Toyota Safety System radar and camera-based setup with auto emergency braking and lane departure warning. Only downside I've seen is that the 12v battery is a rare weird one that costs more.
    If I had to guess (and it really is a guess) a rock got thrown at you and caused a tiny leak in the AC condenser, which is exposed right on the front of the car in front of the radiator. Eventually the refrigerant leaked out and the system tried to compensate for this by working the compressor extra-hard. Eventually the compressor worked itself to death.
    #4 Leadfoot J. McCoalroller, Aug 16, 2025
  5. grayfox
    Wisconsin
    Are you saying the compressor is dead - even though I never turn the AC on? They put in refrigerant and found a leak in the compressor - is that the same thing? I can understand that the refrigerant all leaked out eventually due to the leak. I also realize that a leak may not be fixable so I'd need to replace the compressor. Does this compressor serve any other function than the AC (is it ok to not fix - I just won't have AC)?
  6. Leadfoot J. McCoalroller
    8,291
    7,808
    Pennsylvania
    2018 Prius c
    I'm not saying anything either way about your compressor- I can't tell from across the internet.
    If your mechanic thinks it's leaking internally, then replacement would be the right correction.
    But all it does is create pressure for the air conditioner. If you never use A/C, you don't need a compressor.
    The hybrid batteries tend to last a little longer when they get to breathe cool air- they tend to benefit from the use of A/C. But that one is old enough that it won't make any difference now.
    Sounds like you don't need to do any repair at all if you don't want.
  7. grayfox
    Wisconsin
