New acquisition! Meet Big Red! No MFD connection
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Nov 28, 2021.
  1. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    5CF25312-2D8F-4288-9013-9422E20A2943.jpeg 594DB4C3-78CD-462A-8DFF-31C8CA4A7F1B.jpeg 67077D80-26B5-4939-B276-644589364538.jpeg Hi all. So I picked up and very straight ‘04 with a very straight body. I got it cheap because the traction battery kinda exploded. So I rebuilt the battery with some good plates I had laying around and boom! Runs great, no codes.
    this car has all the bells and whistles, but it looks like someone tried to replace the MFD screen with a serviced one. It comes on with the car, but there’s no connection to the stereo, climate, navigation, or the energy features. I plan to pop it out and see if it’s not hooked up or maybe he got the wrong year in there? Any ideas?
    (ps, anyone who says “why don’t you just buy a new car?” Will be placed on my ignore list)
    vvillovv likes this.
  2. JC91006
    16,939
    8,647
    when you have an exploded battery like that, the modules to each sides of the burned modules are most likely bad as well. You should replace the ones right next to the burned ones.
    fotomoto and Raytheeagle like this.
  3. Ianmeister
    316
    320
    Meridian Idaho
    oh I did. I replaced 12 of them in fact.
  4. Tombukt2
    Tombukt2 Senior Member
    13,879
    2,521
    Durham NC
    I'm interested to know if your MFD part of its unplugged or what the heck could be going on I know somebody here on this list or a similar list found the 7-in screen they bought online plugged it up soldered it up whatever to the rest of the MFD system and it worked I think it was a Panasonic part actually
    SM-A715F ?
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    This would be my guess. IIRC, the MID changed after 04 so odds are they got a wrong year model.
  6. Ianmeister
    316
    320
    Meridian Idaho
    yeah. I’ll look into that. Here’s a picture on the back showing the part number. 9F16094F-39CB-47DA-AE32-D98B905C5793.jpeg
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
  8. Ianmeister
    316
    320
    Meridian Idaho
  9. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Do you know which trim the 04 is?
    The only reason I'm in this thread at all is that I was not aware the 04 had Nav. The other non working parts on your MFD sound an aweful lot like what's in the early Prime plus and LE s'
  10. Tombukt2
    13,879
    2,521
    Durham NC
    I didn't think '04 had nav either I don't even have nav in my '09 but I have the WMP 3 player and all that stuff
    SM-A715F ?
  11. Ianmeister
    316
    320
    Meridian Idaho
  12. Tombukt2
    13,879
    2,521
    Durham NC
    Yep under seat navigation there it is This is an American car US car whatever cool like I said I didn't tell the early '04s had the nav but apparently could be ordered or they did Great so then that means you have to have a multifunction display that works with the nav I guess maybe somebody changed it and didn't realize maybe they didn't maybe unplug it clean the plug and plug it back up and see what happens
    SM-A715F ?
  13. Ianmeister
    316
    320
    Meridian Idaho
    hmmm. There’s an idea. I’ll give it a try.
  14. Ianmeister
    316
    320
    Meridian Idaho
    Hmmm. So I’ve checked the connections. Everything looks ok. Like I said the screen comes on, but if I hit the nav butting it says “external system not connected” but the box under the seat is connected.
    I did notice the stamp on the stereo says March of 2005 when the car was manufactured on December of 2003. I wish my neighbor was an early Gen2 guru.
  15. ChapmanF
    19,061
    I nearly always have to give people the disappointing news that the infotainment diagnostic screens on the MFD are not the screens they're looking for (as, for example, here :)).
    On other hand, every now and then, a situation comes up like yours here, where they absolutely are the screens you're looking for!
  16. Ianmeister
    316
    320
    Meridian Idaho
    I don’t follow you, what do you mean?
  17. ttou68
    ttou68 Active Member
    351
    211
    Are there DVD inside the device underneath driver's side seat?
  18. ChapmanF
    19,061
    People very often get a Prius for the first time, and then they get a problem with the engine, say, and they don't have a scan tool to get the trouble codes, but they read on PriusChat that there are a bunch of diagnostic screens built into the MFD, so they go play with those, and then they will post something like:
    and somebody has to break the bad news to them that those screens on the MFD are only for diagnosing the MFD, audio, navigation, and other infotainment electronics, and those codes they found have nothing to do with the, say, engine codes they need, and they still need a regular scan tool for those.
    You, on the other hand, really are trying to diagnose the infotainment system.
  19. vvillovv
    4,337
    1,519
    NY
    Now the question is (in my mind anyways) can the or will your MFD show the diagnostic screens? Since so many of the other screens are not showing up, yet. I've only seen the MFD diagnostic sreens on the 2014 PiP and the maintenence mode screen on the Prime. And I think to get the gen2 diagnostic screens there is a different (chicken dance) order of button press, brake pedal, light switch or whatever, sequence needed to bring it up.
  20. Ianmeister
    316
    320
    Meridian Idaho
    So in poking around the internet, it seems that my symptoms point to a damaged MFD. It will turn on, but button response time is VERY slow. There is no communication to the car itself even though I have checked the cable connections repeatedly. I'll try another one from Ebay next, or maybe send mine off to be repaired. There is a repair guy out there that guarantees his work, and even describes my exact problem. https://www.autobeyours.com/Prius%20MFD%20repair.htm
