New acquisition! Meet Big Red! No MFD connection
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Nov 28, 2021.
  1. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Yes and others have bought off eBay a raw 7 in screen Panasonic part 66 $ or so and it worked you have this 04 right I've got a perfect in 05 I just put in because it was dim n no good now it's fine but car no more on road..sooo.
    SM-A715F ?
  2. ChapmanF
    19,034
    They do a brisk business in salvage Prius restoration down there, and have a shelf load of MFDs.
    They have so many that it's possible to get them mixed up. I bought a restored Prius from them once and it had the nav unit under the seat, but I noticed when I went to pick it up that they had put the dash back together using a non-nav MFD. They said oops and drove it back into the shop and had the MFD swapped with one of the right ones off their shelf in, like, eight minutes.
    Repair service from them is probably a good option.
  3. Ianmeister
    Ianmeister Active Member
    316
    320
    Meridian Idaho
    its not the screen thats the problem, its the communication between the screen and the accessories in the car.
  4. Tombukt2
    13,864
    2,519
    Durham NC
    Does it at least allow you to do the basic functions it's made to do without the accessories like nav system etc so you can turn the heat and air conditioning up and down and change the radio stations and what have you Yes or no just curious so when mine fails I don't go to a whole lot of whatever to get nowhere
    SM-A715F ?
  5. Ianmeister
    316
    320
    Meridian Idaho
    No, I can’t adjust anything at all. The only thing that works is the animated wheels when the car is in motion.
  6. Ianmeister
    316
    320
    Meridian Idaho
    what's the website for this Prius salvage you're talking about?
  7. ChapmanF
    19,034
    The one you linked to in post #20.
  8. Ianmeister
    316
    320
    Meridian Idaho
    ok so, I’ve been poking around at replacement screens. So what I’m seeing from Toyota is that 47071 is good until 10/2005 manufacture and supersedes 47070. If I read this right either will work? What say you all as I’m going to order a used tested one.
  9. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    yes, the 71 superseded the 70 model. Either should work.
  10. Ianmeister
    316
    320
    Meridian Idaho
    thanks!
  11. Ianmeister
    316
    320
    Meridian Idaho
    Yes! YYYYYYESSSSS! I picked up a new one on eBay and it works! 9321F7D0-9A96-466D-A704-554C5EC30048.jpeg
    Raytheeagle likes this.
