New at climbing hills help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Karen E, Sep 2, 2012.
  1. Karen E
    Karen E Junior Member
    I just bought a Prius V 5 1 1/2 weeks ago and am having a hard time climbing hills...any hints???
  2. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    If it has the same PWR Mode button as the Prius III, that should do the trick.
  3. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    For really steep hills I put my v-5 in Power mode. I typically accelerate to get about 5-10mph over the speed limit and the people behind me off my tail. Then I back off the accelerator and take a more modest approach up the rest of the way, shaving mph off until I'm back at the speed limit by the crest of the hill.
    I've noticed this will eat anywhere from 0.4 to 1.0 mpg off my average mpg when I'm in the middle of a tank, but it usually returns after a few miles back at normal pace.
  4. Karen E
    Thanks..will try this...:)
  5. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Just floor the gas pedal. It doesn't matter what mode you are in. PWR, ECO or no mode selected (aka "Normal") will yield the same maximum RPM when you floor the gas pedal.
  6. ProximalSuns
    1,877
    PNW
    Actually the car is much more responsive in PWR Mode vs. "flooring it" and provides much greater control and range if you are situations where you want the car to apply power.
  7. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    True. But, you can still climb hills in Normal or ECO mode just the same. You just have to use more pedal travel.
  8. rjparker
    rjparker Tu Humilde Sirviente
    10,949
    6,868
    Texas Hill Country
    I keep it in eco and push the gas to keep up with traffic. No traffic, I may let it slow by 10 mph. If you are smart and slightly depress the brake on the way down you are enabling the maximum regen allowing the car to pick up most of the lost mileage in battery power.
  9. vlady
    vlady Junior Member
    42
    Issaquah, WA
    I use mostly Normal to climb hill in my area, sometimes Power (Tiger Mount. and some other hills that graded as 15%). Took me a while to figure out CVT tranny and which mode to use
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    We should be more sensitive to peoples needs, those who are finding a need to use power mode to obtain adequate performance may have weak ankle syndrome. Don't pick on the physically challenged.:)
