New battery-only firmware?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JacquesTutite, Nov 5, 2016.
  1. JacquesTutite
    JacquesTutite Junior Member
    Long Island, New York, USA
    Now that the new Prius Prime has been programmed to run "battery only" til the juice is gone before firing up the gas engine (like the Chevy Volt), do you think they might make that firmware available for the older Prius Plugins? I'd pay to get that!
    #1 JacquesTutite, Nov 5, 2016
    52,878
    that's how mine already operates. how does yours?
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    Never happen... The 51 HP drive motor on a PIP doesn't have enough "oomph" to be safe by itself in emergency maneuver such as accelerating ahead of a non-yielding trucker on an entrance ramp. The Prime has a 91 HP drive motor.
    QuantumFireball and Bluegrassman like this.
    52,878
    oh, if you mean you can stomp on it without the engine coming on, i get it.
  5. JacquesTutite
    Good point, Gallde, thanks.
  6. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Correct me if I'm wrong, but doesn' the PiP purposely stay in the 20 to 80% charge range to prevent early battery failure? I would not want to push the envelope and risk buying a new battery.
  7. bisco
    52,878
    yes, and prime is similar.
