new battery / smart keys NOT working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by monolisp, Jul 27, 2009.
  1. oracle100
    oracle100 Kaizen
    Bay Area, CA
    I used a brand new battery that was above 3.3v and did not work at all. Pulled a used battery from an old unused motherboard that read 3.01v and the fob worked flawlessly. Thank you so much for this info, I would have never figure it out myself.
    tmezz likes this.
  2. Frog88
    Frog88 New Member
    Berkeley, USA
    I can confirm Hans18 finding ! Trouble is that some FOB seems to only work in a very narrow window 3.15V to 3.02V. Most of the lithium battery come in at 3.30V, so they need to be discharged one way or the other !
  3. dolj
    dolj Senior Member
    8,645
    4,396
    Wellington, New Zealand
    The principle may have something to it, but I'd question that range given. I always check lithium button batteries before using and in relation to the fobs I've had no issues with new batteries that were 3.3 V. When I replaced it due to the fob being intermittently unreliable, the voltage on the old battery was 2.8 V.
    It should be taken into account that cheap DVMs are very likely not going to be accurate to the tenth of a volt. so one meter might read 3.1 V when the voltage is really 3.3 V and another might read 3.5 V for the same battery.
  4. Frog88
    Frog88 New Member
    Berkeley, USA
    On one FOB, I just tried a set of 6 'new' CR1632 (including 1 from the dealer tested there at 3.30V) measured at 3.30VDC with a 'cheap' USD20 DVM; none of the batteries will activate the red LED. I put back the 'used' battery measured at 3.01V and it works ... Go figure. I will test the range with a variable power supply and a lab grade voltmeter.
  5. dolj
    dolj Senior Member
    8,645
    4,396
    That is not the correct battery, it should be a CR2032. The CR1632 will be too small of a diameter.
  6. tmezz
    tmezz New Member
    Los Angeles
    2022 Prius
    it's difficult to believe the Toyota Dealer would have charged me $500 for inspecting/diagnosing the problem, and selling me a new fob. the first battery I tried was just over 3.2, and it didn't work at all. until coming here and seeing the post from oracle100 I tried another brand of battery - IKEA brand to be exact - and damn if it didn't work! phew.
