New Battery Tech for old Prius?
Discussion in 'Gen 3 Prius Technical Discussion' started by ElPotato2, Jan 22, 2021.
  1. ElPotato2
    ElPotato2 New Member
    New Zealsnd
    What does the advent of the new battery techs speak for the existing priuses?
    Would it be beneficial in any manner?
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    ive a 2015 hybrid battery in my 2o10 nicer unvented cells
    52,819
    nothing. you can't just change battery tech willy nilly, it's more complicated than that.
    best you can do is get a new pack, there is a small upgrade, although nothing has proven better than a gen2 pack in the long run
    Grit likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    If you are thinking "plug and play", then the answer is NO......because the electronics likely wouldn't play good with a different type of battery.
  5. ElPotato2
    New Zealsnd
    I was thinking more like a solid state battery with the same output spec as the old hybrid battery being swapped for it.
  6. sam spade 2
    7,035
    2,804
    2017 Prius c
    "output spec" isn't the only important parameter.
    The apparent internal resistance at various levels of charge are important too.
    ElPotato2 likes this.
  7. bisco
    52,819
    there is no such thing as a solid state battery
  8. Javed Khan
    Javed Khan Junior Member
    Islamabad
    can we use Li-Ion battery with Gen 3 (2011) Prius?
  9. AzusaPrius
    AzusaPrius Senior Member
    2,254
    942
    Dr. Prius Lithium traction battery is what you want.
    I have it, its lighter than OEM and charges up faster.
    I say its the "Pack of the future"
    Follow @jacktheripper
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Is too. Toyota already made them, just not ready for consumers.
  11. bisco
    52,819
    says you (and orenji) :p
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    Wikipedia claims that Toyota and VW have been working on "solid state" batteries that have solid (not liquid or gell) electrolytes. Sounds interesting.
  13. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I once added an additional information on a celebrity’s Wikipedia page that he once was the tea cup ride operator at Disney world, which wasn’t true.
