New bicycle to minimize short trips
Discussion in 'Fred's House of Pancakes' started by cycledrum, Apr 13, 2012.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    My thinking was don't get burned on performance hybrid Crosstrail with 700c wheels at a mountain bike meetup. That said, I'm well aware Hardrock is only for light mountain riding, nothing crazy or the fork will blow out. It's a little more commited for grocery getting, but nothing a riser stem, bars and grips can't solve.
  2. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Got a u-lock mounted to the frame, replaced quick-release seatpost clamp with allen-key bolt on clamp (Salsa clamps are nice!). Bike pump mounted for long trips. Will use 1 u-lock thru rear tire and chainstay to bike rack and another u-lock thru front tire and fork bridge. Haven't been to local stores much in Prius :D
  3. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Just ordered a 2012 Specialized Crux Comp Disc Apex in the 56cm size. Will also be adding a trailer hitch and a 1up USA rack soon. Boy was that an expensive week. :(
  4. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Started for recreational riding off road but now just ride around town with it or take it to the beach. It fits in the back with the seats flat and front tire removed. Paid about $250 for it and damn its heavy...I've read close to 30lbs. but seeing as I used to jump it and other stuff it's handled it pretty well and the full suspension has come in handy. My other "fun" bike is an old, circa 2005, Trek thats been beaten, and dropped multiple times but still works.
  5. NiHaoMike
    NiHaoMike Member
    98
    16
    Has anyone designed a hybrid bicycle with a proper HSD-like transmission? I see a number of benefits compared to the simpler hybrids out there:
    * The operation of the system is determined mostly in software. You can customize the software to make it operate more like what you want.
    * The default programming could have the HSD perform MPPT (Maximum Peak Power Tracking) to extract the most power. In fact, if you had a way to hold the bike stable, you could use the bike as a stationary bike, with all of the energy being stored in the battery.
    * The fact that a HSD can measure power (MG1 current is proportional to input torque and the input speed is easy to measure) means that the pedal power measurements are really power measurements, not estimates.
    * It's also possible to get regen all the way to zero by pedaling backwards. Once the speed drops too low for MG2 to regen effectively, the backwards pedaling allows MG1 to regen while applying negative torque.
    * The fact that the HSD needs its controller to operate gives a security advantage. If a thief tries to pedal with the HSD not booted, MG1 will simply freewheel and nothing will happen. Even a simple challenge/response authentication method would be relatively difficult to bypass, and you could have a "fake boot" mode where it seems to start up, but gradually shuts itself down after a minute.
    But since bicycles are of limited use in my area, I didn't build one. I did, however, build a pedal generator for my senior design class. (It's just a permanent magnet alternator connected to some pedals though a gearset and some electronics to control the power flow.)
  6. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Ah, a tri-cross bike. Had to look that up. I think with BB7 brakes, both pads move. Says dual knob pad adjustment. (edit - only 1 pad moves, but adjusters for both pads)
    On my BB5's only the outboard pad actuates. Just spent today adjusting them and did a tad bit rotor trueing in front (cause I totally messed up the brake adjustment after turning the adjustment knob like 'what's this do, then squeezed brake lever in garage whoops. :D )
    Been looking at bikes rack sitution at local stores. Some have them, some don't. Kinda sad. Hundreds of spaces for cars to park. Few places to lock a bicycle.
    Gained 1 MPG avg on fuelly since got the bike (55 mpg last tank) :)
  7. Tandem Rider
    Tandem Rider Junior Member
    56
    Indianapolis, Indiana
    The BB 7 brake has only one pad that actuates although both pads can be adjusted. An out of true rotor is the main problem with the Avid brakes but they do stop well.
  8. d2mini
    d2mini Active Member
    519
    106
    Houston
    Divided into the cost of the bike, it will take you how long to recover the bike purchase? :D
    j/k... the rewards of bike riding are many. :cool:
  9. BornPriiOrDie
    BornPriiOrDie Junior Member
    78
    16
    Sacramento, CA
    Hello, sorry I missed your question!
    The hitch installation wasn't *too* bad—a little frustrating with the muffler (had to undo the fastener to put the hitch between the car and the muffler), but that did the trick. We didn't have to modify anything on the car.
    The rack works great on the Prius and the weight of the two hybrid bikes (my husband has the same type of bike I do) is not a problem at all. I often leave the rack on the back of the car.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Here's a dig of a four month old thread. Well, the commuting around town with mountain bike experiment didn't go so well. In fact I bought a real commuter bike last Friday and sold the mountain bike 2 days ago (keeping the road bike and commuter, 2 is enough:)
    pid'd below is the commuter bike, a 2013 Specialized Sirrus Elite. Nice bike. 26 lbs. Best part was $100 off MSRP.
    Pic on the right is the Hardrock mountain bike as a wannabe commuter bike. Looked funny, but could get an extra workout by pedaling extra hard to maintain speed on the road. Passed on that. I like nimble bikes on pavement.
  11. Tim Bender
    Tim Bender Member
    134
    44
    We need more bike threads on PC. I'm a some-times bike commuter. Sometimes I'll go 4 weeks straight bike commuting, other times I'll go 8 weeks without riding. Been bike commuting regularly since 2007.
    I have 2 bikes right now. A Surly Long Haul Trucker touring bike (pictured below with the dog trailer - from a tour last year in upstate New York) that is my primary commuter, grocery getter, tourer, and bad weather bike.
    Touring setup with dog trailer by bendertj, on Flickr
    I also have a Surly CrossCheck (see pic below) that I currently use as a get-around-town bike. Like if I run to the movies or to a ballgame, and just want to wear shorts and gym shoes. No fenders, platform pedals, balloon tires - you get the idea. The CrossCheck has been great - I've had it setup as a cyclocross racer, commute bike, skinny tire road bike, touring bike, and light-duty trail bike.
    CrossCheck Fat Frank Build by bendertj, on Flickr
    cycledrum likes this.
  12. usnavystgc
    3,159
    990
    Tucson, AZ
    Here's my DIY ebike I use for short trips. Its pretty fun to ride and effortless too.
  13. John H
    John H Senior Member
    2,208
    558
    Nice, but where do you carry the beer, and how do you keep it cold?
    I notice it's plugged in. Does the Boss know your charging at work? :)
  14. bisco
    52,891
    backpack cooler. :cool:
    usnavystgc likes this.
  15. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Omg! Brett is still alive!
  16. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    Here is my human powered Prius alternative :
    Tim Bender and alanhu99 like this.
  17. Dmatt
    Dmatt New Member
    75
    I just got back into riding in April. I've lost 23 lbs since then riding twice a week. On the weekend I usually do my long ride which I'm up to 70 miles. I ride from my house to the Pacific Coast Highway and turn around at 35 miles. I'm hoping to ride in the Tour de Tuscon in Nov. It's 112 miles so I've still got a way to go!!
    I got a great deal on a full carbon bike made by Ridely. The local shop was trying the brand out to see if it would sell here in CA since it's made in Belgium.
  18. eco-icon
    eco-icon Junior Member
    137
    heres my CArbon ibis mojo SL. still thinking how to cary it it on my prius. IMG_0083.JPG
    jaymac likes this.
  19. alanhu99
    alanhu99 New Member
    17
    San Francisco Bay Area
    Here's what I had in the back of my Prius this morning:
    Fits in just fine with the back seat down and the rear wheel of the bike removed.
    hyo silver and jaymac like this.
  20. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Ooh, I like that. Tell us more. Is there a low racer version? It reminds me of this:
