New Blower Motor Failing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 09Prius2, Aug 20, 2016.
  1. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Greetings all. After much reading of the board, I have finally decided to sign up.
    I purchased an '09 with 150k miles 3 months ago. Its been great so far except for the blower motor.
    I noticed the blower fan had a chopping or helicopter type sound from the beginning. It failed, so I bought another and replaced it.
    It hasn't been but a few weeks and now the new motor is already working intermittently. Although when I try to start it by hand, it spins up hard enough to nearly take my skin off. Which is what the old motor did when I jumped it to the 12v battery after I removed it, however reinstalled it and it still didn't work so I replaced it.
    Based on what I have found so far, it could be so many different things and I'm just not that familiar with these electronically operated cars yet. As far as I know it could be any one of dozens of different random little connections.
    Any input?
  2. JC91006
    16,496
    8,406
    It's the control module, the little box the motor connects to. Change that
  3. Patrick Wong
    18,200
    6,479
    As previously suggested, the blower motor control is the most likely issue. You can buy a used unit on eBay inexpensively.
    2G HVAC Fan Motor Control | PriusChat
  4. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Thanks guys, this is a big help. I wasn't aware of this component yet, my next step was going to be the relays. I'll give this a shot instead.
  5. 09Prius2
    09Prius2 Member
    201
    88
    FL
    Update. I had ordered the blower control on ebay, and it turns out there were two versions available for this model year, so of course I received the wrong one. I sent it back, and while I was waiting for the return to be processed to exchange it for the correct version, I had reinstalled the old one and haven't had a problem since.
    Fingers crossed and hoping for the best as the old control seems to be working correctly now.
    SFO likes this.
