Featured New Bluetooth Sodium Ion 12 Volt Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by PriusCamper, Apr 13, 2026.
  1. PriusCamper
    PriusCamper Senior Member
    13,468
    5,437
    Pacific Northwest, USA
    Here I am wearing my NexPowerEnergy shirt and hat. I wanted to let you know of this impressive 12-volt battery for sale at SaltyHybrid.com. It costs $175 and allows you to control the battery management system for it with a phone app: http://www.saltyhybrid.com/collections/all-products/products/the-ultimate-12v-battery
    This would be ideal for those who use their Prius to power their home during a power outage because it will give you valuable data about how your system is functioning, as well as allow you to change charge settings/thresholds.
    This battery is also ideal if you live in super extreme cold weather and extreme hot weather because sodium battery chemistry is superior to standard 12v chemistry in extreme temperatures.
    Another valuable feature is it has a power button, which is ideal for people who plan to put their car in storage for long periods of time.
    This product is being sold at near cost by Nexpower, so its not a major moneymaker for them, but an ideal way to compliment the value you gain when you install a salty hybrid pack.
    I got to install the salty GT version for my first time this weekend. Very impressed with the many design improvements and material quality upgrades of this GT pack. Of course, GT V2 is the new one that's currently available with a significantly higher capacity and GT V3 with even more improvements will be available next January.
    #1 PriusCamper, Apr 13, 2026
    Gokhan and jacktheripper like this.
  2. Mike SBP
    Mike SBP New Member
    Chehalis WA
    I took that picture of PriusCamper just before I bought the salty 12v battery to install in my 2007 Honda Civic hybrid. I am pretty excited about the idea that I won't be running into 12v startup problems with the Civic once I get this installed. I will post some pics. I know... it's a honda, but hey, it's a hybrid that is getting a cool upgrade. I look forward to installing the battery app so that I can actually keep an eye on the battery condition, make changes to optimize for my vehicle and all the other things this app can do. Big Thank You to PriusCamper for all the help with keeping my hybrids running!
    Gokhan, ASRDogman and PriusCamper like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Nifty! Sound like a good idea.
    Guess there's an update to the Dr. Prius app for the 12v battery?
    I replaced mine in May 2022... But I might get one, just because...
    PriusCamper likes this.
  4. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    I seem to have this exact same battery from an ebay seller. Is there anyway to disable the light from always being on? Once I press the power off button it switches to 3v mode. Which I think is good when being away for like a month to save from high self discharge. But you would have to use door key to enter the car. Also can anyone test the voltage at rest? I'm getting 16.8v which is very unusual if nominal is 13.2v for sodium ion.
  5. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    I will probably get Jack's Sodium ion traction batteries soon once my existing Toyota modules starts to show it's wear. So far it's still doing fine. All these years with the nickle plated bus bars too.
  6. ASRDogman
    8,067
    4,089
    I doubt you have the "same" battery, from ebay.
    What light?
    When do you get 16.8 volts?
    Are you putting this is a Prius? (n)
    jacktheripper likes this.
  7. jacktheripper
    jacktheripper Senior Member
    284
    561
    Hi @PriusV17, very interesting, can you send me the link to the eBay listing?
    Our 12v battery use the famous/expensive/reliable JK BMS that allow user to monitor and update configuration to the battery. The resting voltage is adjustable and the default setting is at 13.2v. FYI.
    ASRDogman likes this.
  8. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    This seller is not showing consistent information. That's why I didn't install it yet. But the 12v battery looks identical and the app looks identical. Attached are the screenshot of my specs from that app and the links to the seller.
    Specs look the same are yours Jack. But he is calling it LiFePO4 but it looks like Sodium Ion specs. Same exact looking battery just different sticker. Same app.
    Here is the 12v:
    https://www.ebay.com/itm/306619536834
    He sold sodium ion batteries for traction modules also:
    https://www.ebay.com/itm/306500135062
  9. ASRDogman
    8,067
    4,089
    Don't put that in your Prius. It's not designed for it.
    It could be a very costly mistake!
    Get the Sodium 12v battery from Jack.
    And the Sodium Hybrid Battery too.
  10. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    I retested again with a different tester. And now it looks normal. Could have been a fluke with my first tester. Notice the icon on left side of first tester. Probably an error with tester.
    Brian1954 likes this.
  11. ASRDogman
    8,067
    4,089
    Please, post photos when your electrical system fries.....
  12. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    Jack, hope all is good with you. It's been years since we met. Still flying RC's? I've been flying night drones a lot recently. I will get back into RC's in the future. I have an F-14 Tomcat waiting to fly :)
  13. Brian1954
    Brian1954 Senior Member
    2,691
    1,076
    South Central PA, USA
    Why would a 13.01 volt battery fry the electrical system??? Please explain why it would.
    The Prius DC to DC converter outputs 14.1 volts when charging the 12v battery, and it does not fry the 12v electrical system!
    Isaac Zachary and 3PriusMike like this.
  14. PriusCamper
    13,468
    5,437
    Yes, this is because NexPowerEnergy is tired of dealing with DIY buyers who are constantly doing dumb stuff on install and blowing up their customer service costs and have mostly switched to selling pallets of packs (24 packs per pallet) to vendors like HybridGeek, GreenBean and ther certified installers so the vendors and installers can eliminate all the dumb mistakes that DIY installers make. So the answer is yes, these are the same products, but at a higher price than what you can buy at: http://www.saltyhybrid.com
  15. mikk
    mikk Junior Member
    23
    Germany
    Hello,
    I am considering purchasing the NexPower 12V battery from Jack and have a few questions:
    1. Can I use this battery in a 2016-2019 RAV4 Hybrid (Gen-4)? The RAV4 uses a standard Yuasa S46B24R, similar to the Prius Gen-2.
    2. On the product page, there is an option to select a vehicle generation:
    • 1997-2009 Prius Sodium-Ion
    • 2009-current Prius Sodium-Ion
    Is there any difference between these two options?
    Thank you for your help!
  16. ASRDogman
    8,067
    4,089
    Perhaps you should contact Jack for those questions....
    Get it straight from the source.
  17. PriusCamper
    13,468
    5,437
    I just asked and he checked and said it looks like it will fit...
  18. PriusV17
    440
    207
    CA
    2017 Prius v wagon
    The same battery in lead acid costs (which only lasts 4 years or less in my case) costs over $250. These $175 (plus shipping/tax) Sodium-Ion batteries or LFP should last the life of the car. I'm waiting for my existing 12v battery to die before I swap it. Like the Youtube guy video says. It's most likely the wiring or electronics that causes fires, but not the battery chemistry itself. So let's hope they have good electronics and wiring :)
  19. mikk
    mikk Junior Member
    23
    Germany
    It's quite fascinating how the state of charge (SOC) of Sodium-Ion batteries can be estimated.
    With traditional AGM batteries, you can simply check the voltage to determine whether it's time to charge or drive. This is particularly important for people who work from home and only drive short distances once a week.
    From what I understand, Sodium-Ion batteries tend to maintain a relatively constant voltage (similar to LFP batteries) until they are 80-90% discharged. Based on my experience with LFP batteries, the Battery Management System (BMS) typically starts to detect current draw once it reaches around 1-2 amps.
    However, when you park the car with the alarm on, the current draw can be as low as 50-150 mA, which often goes undetected by the BMS. As a result, you can't accurately determine the SOC since the voltage remains nearly constant, and the BMS isn't sensitive to such small currents. This means the real battery's SOC is also not visible through Bluetooth monitoring.
    Has anyone had experience with SOC estimation on NexPower Sodium-Ion batteries? I'm particularly interested in finding ways to avoid missing the ideal charging or driving window, ensuring the battery is charged before it runs out of power.
  20. Brian1954
    2,691
    1,076
    FYI, I can purchase a lead acid AGM battery at my local Walmart on the east cost for $169 + tax. The battery warranty is 4 years.
    It looks like the NexPower Energy 12V batteries only have a 1 year warranty.
    How many years do you think the batteries will last?
    #20 Brian1954, Apr 18, 2026
