New Brake Pads and Rotors Hot!
Discussion in 'Gen 3 Prius Main Forum' started by ElectricCarFan, Aug 18, 2017.
  1. Mendel Leisk
    41,389
    I should post this. It's NOT a well laid out instruction, really glosses over the step-by-step of a "brake inspection", assumes you're doing a complete overhaul, which is rarely if ever the case. But it has a few goodies: torque values, pad thickness, rotor runout specs. Also explains (somewhat) the alignment of rear caliper piston with the pad pin.
    ElectricCarFan and Raytheeagle like this.
