New brighter headlights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by macaronincheese, Jan 3, 2016.
  1. macaronincheese
    macaronincheese Junior Member
    Bay Area
    What is the best after market headlight for a 2015 Prius 2? The stock halogens are not bright enough. Also a local shop to have them installed in the Bay Area (San Jose).
    Thanks
  2. andino
    andino Senior Member
    746
    546
    San Jose, CA
    Just snag a HID kit off amazon or ebay. You can install it yourself or since you're in SJ, I'd be happy to help you do it.
    PriiPrii and Burna J like this.
  3. macaronincheese
    Bay Area
  4. NoPistns
    NoPistns Junior Member
  5. xliderider
    xliderider Senior Member
    6,615
    2,383
    Honolulu, HI
    You use the private message AKA Start a Conversation function. Click on the user's avatar and choose Start a Conversation to message the member.
  6. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    As someone with little auto mechanic skill, it's an extremely easy DIY... I just installed my HID bulbs a few months ago. There's plenty of threads here on PC to help you out if you do some research. Here's a video showing the process as well.
    This is the bare minimum of installing the bulbs and making them work. There's other steps that will help you long-term -- installing a wiring harness to protect your electrical system, doing a headlight housing retrofit so you're not blinding other drivers, etc, but if all you want are brighter HID bulbs, you should be able to DIY in an hour or less.
    avusblue likes this.
  7. macaronincheese
    Bay Area
    Dealeo, HelloHybrid and m.wynn like this.
  8. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    Looking good! Later down the road you may end up doing a retro fit. Haha. That's what I did.
    iPhone ?
    sfv41901 and HelloHybrid like this.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,277
    Palmdale, Ca
    No kidding. Its what most do
  10. eunique
    eunique Member
    66
    89
    US
    I have been using and purchased a LOT of HID kits for multiple different cars from ddmtuning.com and have been extremely happy with them.
    I would suggest to readjust/ re-aim your lamps after installing HIDs.
    And even more so,the driver side so as not to blind oncoming traffic
    OnePlus One?
  11. Markee
    Markee Member
    294
    36
    South Florida Broward County
    Exactly which HID Kit is the most popular ?
  12. xliderider
    6,615
    2,383
    Honolulu, HI
    How much are you willing to spend?
    If money is no object, go with Morimoto H11b kit from TRS (Theretrofitsource.com).
    Otherwise, there are many other more economical alternatives, with a lot of opinions on how good they are.
  13. Markee
    Markee Member
    294
    36
    Thinking about upgrading my headlights wondering if the Morimoto H11b kit from TRS (Theretrofitsource.com).are still the best option ?
  14. xliderider
    6,615
    2,383
    Honolulu, HI
    These quick start ballasts/HIDs intrigue me. If you get them, make sure you specify that they send you the H11 bulbs with the ground wire located between the mounting tabs on the base.
    http://pages.ebay.com/motors/link/?nav=item.view&id=251729328560&alt=web
    I have their bulbs, but not their ballasts. I can vouch for their bulbs, high quality at reasonable prices.
  15. TomasV
    TomasV Junior Member
    52
    Haddon Heights, NJ
    What's the advantage of a retrofit?
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,277
    Palmdale, Ca
    Better light output & a sharper, cleaner cutoff
    TomasV likes this.
  17. A.Reyes
    270
    178
    Beaufort, 29902
    Not much. I've retrofitted my car. Yes the light output is better. I have awesome high beams. And I get a super sweet cutoff. I just don't like that I have to take off my bumper to change my bulb. And that the water tightness is very tight. But it was a quick install.
    iPhone ?
    TomasV likes this.
  18. winglik
    winglik Junior Member
    25
    NYC
    HID kit is easy, cheap and have great result. Installation can be done less than 30mins. No tool needed. Don't get those cheap ebay HID kits. Most of the 35W ballast kits sell on ebay are garbage. A good Ballast makes huge difference. I recommend you the Zenex 50W ballast. I used it almost 2 years, never have any issue.
  19. Markee
    Markee Member
    294
    36
    Is there a particular kit that stands out above the rest that someone can post a link to maybe with some how to install video ?
  20. FinToy
    FinToy Active Member
    145
    141
    Finland
    Installation is basically just plugging in the wires, that shouldn't be an issue if you have ever done anything for your car. Check youtube anyway if you feel unsure.
Loading...
