New Cabin Air Filter, Blower motor service, and Engine Filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Joe Wall, Feb 16, 2019.
  1. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I went to the Toyota dealership and found out my cabin air filter had a lot of debris in it. They said a rodent had been nesting in it. Additionally, they suggested a blower motor service and new engine filter. Any recommendations on cabin air filters and engine filters? Also could I do the blower motor service at home? The quote was pretty high so I wanted to do this at home instead and learn. Thanks!
  2. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
  3. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    52,388
    never heard of blower motor service, not sure what it entails
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Be prepared to flush your wallet into the dealers cash register;).
    Highly doubt an air intake flush is required and will only lighten your wallet in the process :(.
    Change the air filter though(y).
  6. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    The filters aren't that expensive from the dealer. Personally, I get my filters from NAPA, either ProSelect or Gold lines. Some may be more concerned about engine filter quality, but for the cabin air filter, nearly anything that will allow air through but stop twigs and leaf bits will work.
    I don't know what the blower service entails, but you could just stick a vacuum hose in the blower and clean it out. I believe it should be just below the filter.
    jb in NE likes this.
  7. Patrick Wong
    18,210
    6,513
    I am assuming that debris from the rodents got past the cabin air filter. If that is true, then you will want to remove the cabin blower motor to clean it as well as the air ducting leading to the four cabin dash vents. (I further assume you do not care to breathe air contaminated with rodent droppings.)
    James1964 and Mendel Leisk like this.
  8. Zeppo Shanski
    Zeppo Shanski Active Member
    305
    163
    Chicagoland
    Toyota OEM cabin and standard air filters from your dealer in the nice Toyota box are over-priced garbage. Go to any decent quality auto parts store and get any good name-brand filter on sale and you'll be fine.
    I got a very nice aftermarket cabin filter at Advance Auto for $6.50 on sale through the internet. It was there on the counter when I walked in. < 5-minutes to put it in.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    If s blower motor service requires you to remove the ac blower I would just replace it. It’s a well known failure
    At that age anyway. Odds are good if you remove it yourself to clean it it would probably fail soon thereafter only because it’s a pain to r and r.
    There like $50 on eBay. And it is a pain to remove unless you like laying on your back all scrunched up on the passenger side floor. The dealer will drill you hard on that labor probably 2 hours at $140 an hour.
    If you have mouse nest in the filter the car is inhabited by rodents. Take everything out of the rear hatch as there’s probably a nest in there too under the spare tire and they like building little condos in engine air filter box too.
    What really sucks is mice love the taste of Prius wiring and will gnaw on everything and cause a lot of damage $$$$$.
    See lots of mice damage on this site.
    kenmce likes this.
  10. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    I'll just get an OEM filter. Any recommendations?
  11. George W
    George W Senior Member
    911
    514
    San Antonio
    NAPA Gold series filters.
  12. Joe Wall
    Joe Wall Member
    243
    52
    Wisconsin
    Called Advanced Auto and found an OEM filter about $12-$13. I'll have to check NAPA when it's open tomorrow. Thanks
  13. bisco
    52,388
    how can you get an oem filter at an auto parts store? do you mean aftermarket?
    edthefox5 likes this.
  14. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    There is only one “blower” service here and it is coming from dealer’s mouth. Replace filter on your own.
    cyberpriusII likes this.
  15. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,840
    Hyampom
    Denso filter widely availble for around $4. has charcoal for those who believe it does any good.
    TYC available for under $3.50,
    2009 TOYOTA PRIUS 1.5L L4 ELECTRIC/GAS Cabin Air Filter | RockAuto
    BTW, agree with borninblue....Unless there are LOTS of debris that got past filter, would not worry. BTW, even then you can get most of it out without too much hassle and without removing blower motor -- something you should avoid
    #15 cyberpriusII, Feb 17, 2019
    edthefox5 and Stevewoods like this.
  16. Stevewoods
    Stevewoods Senior Member
    663
    1,200
    Seattle, WA
    i would skip the charcoal. If a filter with charcoal was ripped, torn, think of the mess it would cause blowing into the cabin.
  17. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Denso is the OEM filter. They sell them on rock auto.
  18. Skibob
    2,912
    1,505
    Northern California
    Because Toyota does not make them themselves, they buy them from other companies and put their name on them. Denso is the OEM manufacturer of the filters. If you buy a Denso filter it’s the same thing.
  19. Stevewoods
    663
    1,200
    Seattle, WA
    yeah kris gave the link to rock auto above;)
    But, if he were having rodent problems i would not use a charcoal filter. Big mess possible.
  20. bisco
    52,388
    How do you confirm that a four dollar denso filter is the exact same as the thirty dollar Toyota?
