New car , first Toyota, first hybrid - help!
Discussion in 'Gen 3 Prius Main Forum' started by gmaur, Jun 7, 2014.
  1. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Your average is affected by the limited distance you have driven. In time you should see it approach what most people in your area can expect. there is also good advice above, re just letting it do it's own thing. ECO mode will help train you to get used to not having lead foot acceleration.
  2. Feri
    Feri Active Member
    761
    144
    No!
  3. Feri
    Feri Active Member
    761
    144
    Ignore this. It means sitting and letting the engine ( otherwise referred to as the ICE, Internal Combustion Engine) warm up and charge the battery. It gains you nothing in the long run.
  4. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Pretty much everything goes off except the computer that organizes the door locks/lights.
  5. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    No.
  6. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    I find nothing in the manual about a "low gas" warning light so I assume their is none, correct? I was accustomed to having that little feature and I think I'm going to miss it.
  7. fuzzy1
    10,463
    The last bar on the fuel gauge starts blinking, roughly 1/2 gallon after the second bar goes dark, or when 'Distance to Empty' drops to roughly 25 miles. But it doesn't change color, so it easily missed.
    There is also a single 'beep' the moment this bar starts flashing, but this can get lost in loud music or road noise. This beep repeats every time the car is restarted without a refueling.
    This warning leaves a significant safety margin before the car actually runs out of gas. For an estimate of how much fuel and range really remains, read the first post of this long thread:
    [WARNING] Running out of gas (Gen III)
    #47 fuzzy1, Jun 13, 2014
    Merkey likes this.
  8. Troy Heagy
    Troy Heagy Member
    1,218
    That's why your MPG is low. (True city drivers never achieve the EPA's advertised city MPG.)
    By the way you need to drive a car at least 15 minutes to get the oil hot enough to vaporize the water it absorbs. Right now in summer it isn't really a problem to heat-up quickly but in the winter it will be. Water in the oil reduces lubrication and, when the car is sitting, causes internal corrosion. I'd recommend driving the Prius (or any car) once a week on the highway. Like Sunday morning.
  9. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    With such low usage you might have a problem with the 12 volt battery.
  10. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    Prius Plug-in will do best for him if goal is saving from gas.
  11. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    Over the past two days, I've taken the Prius on a couple of trips (total of 55 miles) using ECO mode exclusively and using a combination of HWY (60-65MPH) and city (30-45 MPH) driving. The MPG for these 55 miles is reading 41.2. I think, based on my limited knowledge, ECO is probably the mode for me.
    When I shut down last night, the battery was at 3/4 full. This morning the battery is reading only 3 bars, or less than half full, so I'm still not sure what that's all about. When I did shut down, I left the AC and radio on...as it's a habit from my previous cars...but I think I will try this next week turning them off before I power off just to see what happens. The manual does say, the audio system can have an impact on the battery and does advise turning it off...even in heavy traffic when driving at a slow speed for an extended period of time (whatever that is?).
    I've read elsewhere, that when leaving the car parked for 2 weeks (while on vacation, etc) that there is a button underneath the steering wheel on the left hand side that disconnects the battery and this should be done to prevent the battery from draining. Has anyone ever done this? Does this apply to Gen III vehicles, or just older models? I can't seem to find anything more about it.
  12. Heat Gun
    56
    Read my thread, I had similar experience with my Prius (brand new as well)
    Battery drains while parked under the hot sun | PriusChat
  13. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    People seem to forget that the so-called advertised MPG is not a promise, of any sort. The measurement was originally created to provide a standardized basis of comparison. It's actually just a number for rating, not an expectation. Reading the information provided on the window-sticker, you'll see there's a range stated, that the big number is really just an average.
    So, things like short trips are not necessarily accounted for. Efficiency will be much lower if driving just within the warm-up time. It will be lower in extreme temperatures and at very high-speeds too. There are also circumstances when efficiency is much higher, like suburb driving with few stops.
    To complicate matters, many new Prius owners have no idea what their previous vehicle actually delivered. There was no MPG display available, so the ups & downs were never known.
    Things like that contributed heavily to the slow growth of hybrids. Then EPA made adjustments to their measurement process, taking better into account the circumstances not originally considered when the standards were first established. Now, we're finding out the values themselves aren't being properly reported. Ugh.
    energyandair likes this.
  14. fuzzy1
    10,463
    False.
    The raw CAFE city test cycle is 11 miles long. Shorter distances on cold engines will produce lower numbers that the raw CAFE city figure, just a hair over 70 mpg.
    But the EPA city figure is substantially discounted from that, and averaged in with other tests, including a cold test. That leaves quite a bit of room to beat EPA.
    When I was commuting, the 18 mile route each way was long enough to outweigh the cold start, easily beating EPA and sometimes beating even CAFE even when taking a 100% city route.
    #54 fuzzy1, Jun 14, 2014
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    City cycle is about 23 mins long, 17 stops. At one section, it goes above 55 mph.
    Merkey likes this.
  16. Troy Heagy
    Troy Heagy Member
    1,218
    I apologize. Replace "never" with rarely.
    I certainly didn't get the EPA city score in my Prius in downtown drive of L.A. My score was 10 below the EPA score (which is based upon LA so should have been accurate). I doubt other people get good MPGs in the typical "redlight on every block" drive of a city.
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That's clearly more extreme than the EPA city cycle. You won't get EPA figure.
    Before we moved, I had 2 miles commute with 13 redlights and a stop sign. In that year, my gas efficiency was 56 MPG.
    That's because EV miles allowed me to avoid using gas. ;) PiP is cleverly set up.
  18. gmaur
    gmaur Junior Member
    22
    Dearborn, MI
    I was worn out after the first 9 pages of that thread. :LOL: But, I did get the gist of it and I'm glad there are some brave enough to make tests of that sort. I'm also glad to hear the car does give some warning...a beep and the flashing bar is enough for me.
  19. fuzzy1
    10,463
    That is why I suggested reading just the first post. :D
    While some important stuff was discovered half way through the thread, Post #1 alone has most of what you need to know.
  20. fuzzy1
    10,463
    I would replace 'rarely' with 'frequently', but quite dependent on the conditions.
    Even in L.A., 'city' will have a very wide range of meanings to different people in different situations, and conditions on many routes likely have changed substantially over the past four decades.
    The Federal Test Profile clearly doesn't run into a red light on most blocks, but only 23 red lights in 11 miles. In my area, that is equivalent to about 175 blocks total distance, or red lights at average spacings of 7 to 8 blocks. Places where drivers hit red every block or two, or take two or more cycles to get through each light, are considerably more harsh.
    #60 fuzzy1, Jun 15, 2014
