New catalytic converter, lost 10 mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by JC91006, Nov 8, 2015.
  1. JC91006
    16,936
    8,646
    Not sure how this can happen, I put in a magnaflow cat in a 2006 and lost 10 mpg on a 300 mile drive. Anybody know how this can happen? Mpg at only 35 now
  2. 48mpg
    48mpg Member
    193
    47
    florida
    I
    did you change the oxygen sensors?
  3. 48mpg
    48mpg Member
    193
    47
    florida
    I
    is the flow going in the correct direction??
  4. JC91006
    16,936
    8,646
    I don't know if there's a flow direction to a cat, is there?
    No oxygen sensor, just cat. P0420
  5. Topp Cat
    Topp Cat Member
    71
    66
    Why was the cat replaced?
  6. JC91006
    16,936
    8,646
    Got check engine with p0420
  7. 48mpg
    48mpg Member
    193
    47
    florida
    I
    not sure about direction, just a thought.
    I was told to change the O2 sensors with the cat, of course it might just be a way to get more money out of me from the muffler shop.
  8. JC91006
    16,936
    8,646
    A muffler shop installed it, I hope they would know if there's a specific direction of flow.
    My guess is bad gas from samsclub and my engine is not running right at highway speeds. My latest tank with Costco gas and local driving, I'm back up to 45mpg avg.
    I'll run another 300 miles on the highway in the next day or two, see how that goes
  9. 48mpg
    48mpg Member
    193
    47
    florida
    I
    bad week for repaired prius, my battery rebuild failed,took out for a fast coffee run this morning and its got the same problem as before but the red triangle has not come back, YET..shit happens with old cars..
  10. Silvertn350
    Silvertn350 Junior Member
    64
    51
    Tennessee
    a P0420 is most commonly the downstream o2 sensor , with an upsell of a new cat. Sometimes the cat is needed and can be confirmed with a flow test. Did the P0420 come and go or remain constant?
  11. JC91006
    16,936
    8,646
    The check engine came on for a while then off. I only got p0420, no codes pointing to sensor.
    Check engine light has not returned since cat replaced
  12. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    cat?...looks like a dog to me...
    do you think they cut off 12v power during the repair? Sometimes seems to need a tank or so to reset after that. Or maybe ran it low.
    PriusGuy32, usnavystgc and AzWxGuy like this.
  13. JC91006
    16,936
    8,646
    I'm thinking of disconnecting the 12v to see if things change. It seems the gas engine is the problem, highway is where I'm losing the mpg. I made a 300 mile trip and average 35mpg. But during local non highway driving, the average was 45-46mpg. Again I made the return trip of 300 miles and again the mileage dropped to around 35mpg. So it's my gas engine that's causing the issue, not the electric hybrid side.
  14. JC91006
    16,936
    8,646
    Fixed the problem by cleaning the maf sensor and resetting the car.
    usnavystgc and wjtracy like this.
  15. JC91006
    16,936
    8,646
    The problem is resolving itself but with the new Cat, there's still a little loss of MPG. I think the OEM stuff is just superior to the aftermarket. Overall I might be down 2-3 mpg, not the 10mpg I was experiencing earlier.
  16. ACRtechie
    ACRtechie New Member
    If Cat was originally poisoned by the engine (ie high miles oil-consuming engine, tune up-starved, oil/gas additives etc), those conditions will still deliver poor MPG, and will eventually poison new Cat too if not corrected. An exhaust restriction inadvertently welded into system will show as loss of power at higher speed demands along with poor MPG. Sustained slower highway speeds, however, should still result in good/normal MPG with slight exhaust system restriction (1-1/2" pipe 86" long is not much for a 1500cc engine. Personally had deep rock ding that may have ruined my Cat.
    Air/Fuel (front A/F O2) sensor should definitely be replaced when doing Cat with OEM Toyota A/F sensor (1 hour or so job for experience dealer-tech via windshield wiper assy/rain pan access, NOT the excessive 4hrs and $700 as some stealer/dealers claim, $400 dealer max, DIY=$150 been there did one). But keep in mind, there are many many reasons for poor MPG as we all know, even low tire pressure and/or wheel alignment.
    Really registered and came to PC, for first time however, to post sneaky little Smart Key advisory and/or fix I found, just couldn't resist on the Cat/MPG :)
    JC91006 likes this.
  17. JC91006
    16,936
    8,646
    Welcome and thanks for the write up. I don't think anything has changed to my system, no exhaust restriction welded. My car does burn oil so that's probably what poisoned the original cat. Just cut off old cat, weld on new cat. Seems like driving around 70mph, I can maintain good steady 45mpg+, but once I go beyond 70mph, that's where it would starting dropping mpg (especially climbing hills). Before the new cat, I don't remember the car being so sensitive to mpg at over 70mph. I believe the aftermarket Magnaflow cat is just not as good as the OEM.
  18. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Some catalyst poisoning is reversible, with operation at high load being all you need to restore the cat.
    I have an 82 pickup with ~400k miles, a 92 Camry with ~200k+ miles, and a 05 Prius with ~200k+ miles, all passing smog on the original catalytic converters. I'm not sure if you still have the old cat, but it might be worth hanging on to.
  19. Dion Kraft
    Dion Kraft Member
    305
    92
    Washington, UT
  20. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
