New catalytic converter, lost 10 mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by JC91006, Nov 8, 2015.
  1. Dion Kraft
    Dion Kraft Member
    290
    86
    Washington, UT
    Many times if the sensors are the same you can swap them out and see the efficiency of their operation using a scan tool. You can also use a DVOM as well to to check the efficiency at the component level. I use a Fluke 98 and Snap on Solus Ultra for those jobs. Its always better to check the cheapest component instead of replacing the biggest cost: The CAT to be sure. If the same O2 sensor is used buy one and check before and after positions of the cat to compare. In a setting where the owner is not doing the work they will almost always look for the biggest component for profit. Thats why the auto industry gets a bad rap in regards to repair. Some states don't even have laws where a cap on the max price for repair is not agreed upon. But I'm getting off base here - my bad...
  2. Mochabuzz
    Mochabuzz Junior Member
    46
    SoCal
    How many miles does your car have on it?
