New cells in gen 1
Discussion in 'Generation 1 Prius Discussion' started by Solerno, Apr 18, 2018.
  1. Solerno
    Solerno New Member
    Winchester VA
    2001 Prius
    Hey, guys, I have a 2001 with a bad cell. I have 2 balanced gen 3 cells I'm planning on making fit into the block with the bad cell. Does anyone on here have experience with this/warnings before I go ahead?
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I could be wrong, but I think you can't mix different generation cells. Differences in size and architecture.
  3. Solerno
    Solerno New Member
    Winchester VA
    2001 Prius
    The newer gen cells are longer than gen 1, but I'm told it's still able to physically fit. I mostly want to make sure I'm not going to screw up the computer or something. The shop I ordered them from said they have put them in gen 1's with only a little extra work. He also told me that as long as I replace the block(both cells) with the same gen cells it won't throw any error codes since they are the same/balanced.
  4. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    The 2nd and 3rd gen modules are compatible with each other,but neither are compatible with the 1st gen modules. You really don't want the rest of the 1st gen modules anyway. They're all probably shot and about to fail. You're better off to replace all 38 with 3rd gen modules, or buy a brand new one from Toyota. It won't be a cheap fix, but it will be a good one.
    dolj likes this.
  5. Eric Baker
    Eric Baker Junior Member
    Blacksburg, VA
    2014 Prius v wagon
    You can use "gen 1.5" modules in your gen 1. Supposedly these are revised versions of the gen1 module and are identifiable by the metal foil on the side.
    I can't post a link yet but search ebay: gen 1.5 prius modules
  6. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    SFO likes this.
  8. Eric Baker
    Blacksburg, VA
    2014 Prius v wagon
    Those are the ones I purchased. All had to be deep cycled to restore capacity. 2A down to 6.0V, fully charged, back down to 6.0A, then fully charged again. Most were >2.5Ah at 2.0A discharge after cycling with some up to 4Ah. Not bad for aging fairly cheap cells.
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    It will be hard to make the bussbars fit if you are mixing longer and shorter modules. The posts will be farther apart than when stock. And the buss bars can't really be stretched to allow the longer distance.
    You could make your own step-shaped buss bars for a better fit. Get a length of copper, cut, shape, drill it to fit.
    Usually you would swap all of the short modules for an entire pack of longer modules.
    I would not recommend mixing gen 1 modules with other gen modules. There ican be too much variability which will cause problems. I suppose you could try installing a charger/discharger to try to mask the differences.
    Realistically I would just go back and get some gen 1 modules, or swapping all for newer gen.
    bwilson4web likes this.
  10. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Were they the same size as the original gen 1 cells? I almost (tho not quite) wish I needed a rebuilt or new battery. My battery, which was installed in late 2013 probably has these upgraded cells already. Upgraded=assumes that the Ebay seller knows what he/she is talking about.
  11. YotaWorxs
    YotaWorxs Junior Member
    Los Angeles
    Hello, I’ve done this before. It will take a little modification by making your copper bar in an s shape but they will fit and work. I’ve done this 3 times and the vehicles are still on the road. Just my experience.
    SFO likes this.
