Featured New Crash Tests - Prius Prime and Chevy Volt top picks
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Feb 1, 2017.
  1. Tideland Prius
    16,556
    Not sure. I recall the Citroën DS with the hydraulic suspension also had swivelling lights.
    Toyota has been tinkering with adaptive headlights. I don't think they ever made it down to a Toyota-branded product in North America. Hell, HIDs barely made it down (Solara, Avalon and Sienna).
    The Prius still doesn't have adaptive headlights. Lexus has removed adaptive headlights when it moved to LED lighting on some models (like the ES). More expensive models kept the adaptive headlight function.
    The Mazda3 is still the only compact car with adaptive front lighting. Toyota decided to go the other route with offering standard LED low beams in the Corolla (and now offering full LED headlights in XLE and XSE models).
    RCO likes this.
  2. Prodigyplace
    12,560
    11,778
    Central Virginia
    Some components and features of the car were innovative and ahead of their time. The most recognizable feature of the Tucker '48, a directional third headlight (known as the "Cyclops Eye"), would activate at steering angles of greater than 10 degrees to light the car's path around corners. At the time, 17 states had laws against cars having more than two headlights.Tucker fabricated a cover for the cyclops center light for use in these states.
    Ashlem, RCO and giora like this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    The earliest Citroen DS, I think in the 50s, had fixed lamps. Later models possibly Pallas had the swivellers. I am open to correction on that, but remember some variants had tail/brake lights that got progressively brighter the harder you braked.
    Mais, ou est tous les hommes?
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The 4 led matrix adoptive headlights of the 2017 Prius PHV spread the light when cornering, not swivel.
    The Prius Plug-in Hybrid’s energy-conserving four-lamp matrix LED headlights incorporate unique, speed-sensitive, adaptive beam technology. Using a light-sensing camera to detect the headlights of oncoming vehicles and tail lights of those ahead, it automatically adjusts your headlight beam so as not to dazzle drivers ahead. It even varies the angle and depth of the light beam to match your vehicle’s speed and help spread the light when cornering.
    From EU site.
    RCO likes this.
  5. hill
    8,804
    [quote".... ]While the IIHS scoring is extremely helpful when choosing a vehicle, and provides telling information about the vehicle’s strengths and weaknesses, sometimes you have to read carefully. Other vehicles that actually fared worse than the Model S in crash tests ..." [/quote]
    Driver Walks Away Unharmed After Big Rig Rear Ends Tesla Model S
    Fortunately, even the truck drive walked away. So you gotta pause in awe ... a tesla damaging a semi as much as the semi damages it ... I hope the volt or prime never have to face the same real circumstance. I'd guess it's a bit differeny between a society's test - driving into an unmovable block of concrete or steel, versus the real world where all elements may be on the move. Time will tell.
    #25 hill, Feb 4, 2017
    RCO likes this.
  6. Prodigyplace
    12,560
    11,778
    Central Virginia
    IIHS tests front collisions. Their tests are meant to simulate a collision with the same size and weight vehicle. They do not test for rear collision damage.
    In this case the test designation is immaterial to the collision event.
    #26 Prodigyplace, Feb 5, 2017
    RCO likes this.
  7. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Aren't their tests simulating a collision with an incompressible stationary object?
    If colliding with another vehicle you would have twice the crumple zone distance.
  8. Prodigyplace
    12,560
    11,778
    Central Virginia
    They do a side impact crash test too.
    Model S results are at Vehicle details
  9. Zythryn
    6,408
    4,407
    Thanks for the link.
    Very impressive detail about the tests.
    So some of the tests do simulate a vehicle to vehicle collision (although not necessarily the same sized vehicle).
    According to their site, the small overlap test simulates collision with a rigid body and not a vehicle.
    Odd that they say it simulates a collision with a tree, post or car, as the car would behave differently, wouldn't it?
  10. Prodigyplace
    12,560
    11,778
    Central Virginia
    True, but how would you standardize the test to be as fair as possible?
    IIHS noted this in a news article mentioning the Tesla:
    Although the i3, the Volt and the Prius all did better in the small overlap evaluation than the Model S, the results can't be compared because the Model S is larger than the others. Since the kinetic energy involved in a front crash depends on the speed and weight of the vehicle, the Tesla's acceptable rating is based on a more severe crash than the good ratings of the lighter cars.
  11. Zythryn
    6,408
    4,407
    That makes sense. And don't misunderstand me, I am not suggesting we standardize the tests for size, as larger and smaller vehicles behave differently in crashes.
    I was simply disagreeing with the statement that the tests simulate a collision with a vehicle of equal size.
    That is not the case.
    Thanks to your link, I discovered some of the collisions do simulate another vehicle, while some do not.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
  13. hill
    8,804
    actually - no i'm not talking 20yr difference issue. No denying new cars are safe. But my point got lost via my disjointed writing - so i should have linked to what i was getting at. It's really kind of a common sense thing, too;
    Heavier, pricier vehicles are safer, research finds
    So yea ... in short, whether your Honda is 20yrs old or 20 days old ... mass invariably wins. That 2017 - winning 5star NTSB rating is not to be discounted ... but that lighter/new 5star winner - realistically is still no match for a dirty heavy 13mpg' 71 Olds Cutlass, in many real world accident scenarios not covered by the accepted tests.
    The trick is to make that 5,800Lb-6,200Lb car get around 90-100mpg(e)
    ... if only there were such a car
    RCO likes this.
