New disabling symptom on 2007 w/85,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by jaw444, Feb 9, 2021.
  1. jaw444
    jaw444 Member
    283
    27
    San Fernando Valley CA Van Nuys/Sherman Oaks
    i barely drive my car, i got it preowned in 2009 january, i used to drive a lot on my job and got paid for mileage. I retired in 2013 and no longer drive unless necessary. i realize that's not good for the car. So, i need to start from here.
    i'm in the San Fernando Valley in LA.
    i went to the car this morning to start it, it seemed to start normally, quickly, and all the lights were on the displays. i noticed the red triangle which i saw the last time i started it or the last one i remember, and it quickly went away while all the normal lights were there so i thought it was just part of the normal start up. i noticed there was that little orange light that after looking in the manual is called Malfunction Indicator Lamp. the motor wasn't on, all the other lights went off and just that small orange lamp with the word Check next to it remained. That light eventually went away. It's dead.
    i would like to find out if this sounds like any particular known things it could possibly be.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,070
    956
    Southern California
    jaw444 likes this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    No ones driving there car much anymore that's certain death for an old gen2 Prius. First it kills the 12 volt battery then it kills the hybrid battery. Not driving an old Gen 2 is the worst thing you can do to that hybrid battery hundreds on this site have failed.
    And thousands that never even go on this site. The fact your car has such low mileage has 2 strikes on that battery already.
    Get a dc voltmeter check the 12 volts at the front jump point. Not necessary to go to the battery in the back the front jump point will tell you all you need to know.
    jaw444 likes this.
  4. jaw444
    jaw444 Member
    283
    27
    Thanks. I am unknowledgeable and unskilled mechanically. i have AutoClub road service . i think they can check the 12V. i've had dead batteries recently, at least twice and they came out and just charged the under the hood battery and i had to drive around and go on the freeway for up to an hour. One of those times, the Malfunction indicator light went on. After AutoClub it was running but i was afraid it was something worse and i went to a mechanic i've never been to before but he thought it would be ok just from charging it (this was about a month and a half ago).
    Since i don't have near by mechanic i stayed and talked to him for a long time to get a feel for him, nice guy for sure, i haven't had a trustworthy nearby mechanic in a long time, so i would trust this guy but what i don't know his Prius experience, it's a japanese car mechanic, but who knows how many older Priuses they work on.
    i had a couple of problems with the car in 2019, and after visiting Prius Chat i took it to Avi at Hybrid Fix and would go to him in a heartbeat but too far from me for something simple. If it needs major repairs i'll go to him so i want to find out. i had first taken it to a mechanic near me, they seemed both unknowledgeable and untrustworthy, they have me an estimate of $10,000 to $4000 for the bare minimum. Because the sleazy fake mechanic had erased all the codes, and it wasn't showing the problem at the time of that visit to Avi, there was nothing that could really be done, though he spent a long time on the other problem i was having.
    So i'm going to have AutoClub come out now and check the 12V, it's been a while since i got a new one.
    i have a rental car reserved to go and pick up, i hope the car works after AutoClub and i can cancel that car. thanks again!
  5. jaw444
    jaw444 Member
    283
    27
    Thanks for the bad news. i am mentally prepared to replace the hybrid battery if i have to, maybe a used one, and take really good care of it.
    Do you mean if the 12V is worn out, it won't help to get a new one? If the volt meter shows at the front point that it's dead, is that fatal to the whole car?
  6. bisco
    52,886
    no, the 12v doesn't affect the rest of the car in any way, except that it won't start properly.
    check the voltage and if it is below 12.4v with the car off, charge it up and see how it holds. if it is over 4 or 5 years, just replace it, but make sure the new one is fully charged.
    the hybrid battery is on its last legs at 13 years, but who knows when it will need replacement.
    when it does, get a new one: 'newpriusbatteries.com'
    used/rebuilt are not reliable.
    as for the orange light with the check, is it in the owners manual?
    jaw444 likes this.
  7. jaw444
    jaw444 Member
    283
    27
    thanks for hybrid battery link/information.
    Yes the orange light is in the owners manual, it shows an illustration of the Instrument Cluster, and the Multi-information display (overview). The orange light i was seeing is in the instrument cluster to the right, it looks like a little engine with the word CHECK under it. In the manual under malfunction indicator, it says 'there is a problem somewhere in the engine, hybrid system, throttle control system or warning light system itself.'
    my 12V battery invoice shows it was bought in May 2014.
    AutoClub came and hooked up their device to the front area and he got in the car and started it himself. i asked if he would check the 12V battery voltage. He wasn't really answering the question. He said the car needed to charge for 45 minutes, he said, and i had never heard this before, that could leave it in my closed garage and it would charge with the engine off. He was saying because it's a hybrid, the key is in it and it started up, all the instrument lights came on etc, but it shuts the engine off to save gas and that meant i won't get exhaust fumes in my garage too much. i said the other guys always told me i had to drive it around and i asked about the exhaust fumes, he said no, i could just leave it to charge in the garage, because it's a hybrid, He said "If you want to go out and drive around, suit yourself." I had a hard time understanding him, just because i never heard of those things before. Right now the car is idling in the garage, or if it's not called idling, then it's charging itself in the garage.
    i am supposed to pick up my rental car now, but i think they're open another hour. i want to wait and see if my car starts before canceling it. i think it will start because i think this is like what happened in December, with that same orange light.
    The AutoClub guy had some problem with checking the 12V voltage, i'm not sure what was going on. maybe he did check it, but at one point he said impatiently "would you stop saying 12 volt!" He didn't want me to say it. He said "the charging system is fine." He asked how old my 12V is and i said i would have to look at the invoice and i said it was pretty old. He started to go in the back where the 12V battery is but then changed his mind. this was not the easiest to understand communication, then he said i should check the invoice and see what it tells me to do (English was not the first language for him, maybe that was part of my understanding problem?), and he was saying i should do that later, not then because he was done and he was leaving. I asked if he would just check the 12V battery voltage while he was here and he said i should check the invoice. He said if you check it later and it's too old, we can come back, just call us. my brain was pretty fried and i let him go not remembering that every time they come out i have to pay $90 because i used up my 4 free ones for the year. Anyway, i found the invoice and it says it's almost 6 years old. no idea what the voltage is. i might have to call them again. i'm going to go check if the battery is charged now (he did tell me to run it every 3 days or so from now on).
  8. ChapmanF
    19,049
    He's mostly right. In a Prius, the 12 volt battery is being charged whenever the green READY is showing on the dash. Doesn't matter if it's driving or sitting still. Doesn't matter if the engine is running or stopped. If the dash says READY, the 12 volt battery is being charged.
    The part he wasn't right about was the 45 minutes. A Gen 2 does not charge the battery quickly at all. If the battery has been fully drained, the car will have to sit in READY for around 15 hours. (Or, you can connect it to a roughly 4 amp charger and plug it in, which will require about the same amount of time.)
    If you have a completely dead battery and you try it again to see what happens after only 45 minutes, you'll still be trying with a mostly dead battery. Which you might call slightly alive, but not by much.
    jaw444 likes this.
  9. jaw444
    jaw444 Member
    283
    27
    thanks -- i checked the invoice on the 12V, it was bought in May of 2014 so i'll take it to Toyota tomorrow and get a new one.
    The garage did smell like exhaust when i just went out to check if it turns back on, but mildly, not as much as it would be the engine was making exhaust the whole time. The car started up OK. So if 12V is not holding a charge, it may hold for a day or more but what happened today will keep happening? It's been 2 weeks since the last time i got it charged.
    If i get a new one from Toyota, i would like to make sure it's fully charged. Should the service record show what the charge on it is?
    i also want to get a record of what the charge is on the current battery that i'm replacing.
  10. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    DO NOT LEAVE THE GARAGE CLOSED WITH THE CAR INSIDE IN READY MODE! The gasoline engine will start and run as needed to recharge the HV battery- so you can fill the garage with potentially deadly exhaust fumes. Cars are cleaner out the tailpipe than decades ago but still- it's a bad thing to do.
    jaw444 likes this.
  11. jaw444
    jaw444 Member
    283
    27
    Thanks -- i appreciate your emphasizing that! The room i was in is just across the patio from the garage inner door, and i thought after a while my eyes were burning a little.
  12. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Its easy to get tuned around in the middle of a car issue and leave the car in READY which means in this car no constant noise to tell you its on the engine just had not started.
    It does give you a loud beep when you try to walk away with the fob though. Unless you have no SKS.
    jaw444 likes this.
  13. jaw444
    jaw444 Member
    283
    27
    Thanks to all you guys for sharing info and help with my mechanical illiteracy and disorientation. Before i got the first reply here, i was immediately ready to have my car towed to a new mechanic who i hoped would know what he was doing, i wanted to get started on having whatever major repair it needed, due to desperation for a working car. Now, i am ready to take my time more, having it in better perspective. I do feel in a rush to get a new 12V battery installed and i want to have a good well charged new battery competently installed, friendly to my hybrid battery. i would take it to the dealer which is only about a half mile away but the Yelp reviews are so bad, ever since they were taken over by another company and restaffed.
    Last night i came to check this thread and i couldn't connect, i got a 521 server error. not sure what that means but something about being blocked by priuschat. it continued today. i tried it this afternoon and it connected. i read something about my ip addressing being blocked, not mine in particular but that this can be a cause of the error. or an explanation of it.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    The server was down for everyone, so no worries.
    Keep in mind, the 12v battery on a Gen 2 is small compared to the majority of cars. It's under constant drain, even when the car is off, because it's always looking for the key fob, among other small electronic things that are always on. A brand new battery in a Gen 2 will last about 6-7 weeks before it is completely depleted just due to normal drains when not being used. This can be extended a few more weeks by turning off the SKS system using the small button located on the dash below the steering wheel that says "KEY". The best medicine is to drive the car at least a little bit every week.
    jaw444 and donbright like this.
  15. bisco
    52,886
    when you decide to buy a new 12v, you have to ask them to put it on a charger before you come in.
    even then, they probably won't but say they did.
    then you have to ask them to put a meteron and show you.
    alternatively, you can buy your own charger and meter.
    if you just put the battery in the car as is, it would be a good idea to drive it for a long while. or leave it ready outside, as mentioned above. 45 minutes will not do it.
    if the battery comes at 12.6v, it won't charge much higher at 45 minutes, if at all.
    if you're not driving much, you should buy a maintainer, which will accomplish everything you need.
    keep in mind, you don't have to access the battery, there is a 12v jump point under the hood, connected directly to the 12v battery positive terminal.
    at 6 years, i would just buy a new ine, but you don't have to, if you want to charge it and keep an eye on it.
    the check engine light can be as simple as a loose gas cap, or more complicated in the emissions system. get the 12v right first.
    jaw444 likes this.
  16. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    The 12v is small, charges slowly in the vehicle, and on a Gen2 the Smart Key System can run down the 12V when it sits. There is a Smart Key OFF button under the steering wheel that is good to turn off the Smart Key system when the car is sitting more than few days.
    After that we can tell you more things, but you are getting some flavor above.
    jaw444 likes this.
  17. jaw444
    jaw444 Member
    283
    27
    Thanks -- if i have the SKS off, does that mean i won't be using keyless entry and and won't be starting up the car without the key? I will do that until i get a 12V battery, when i find someone to get it from, and a maintainer would be ideal because i usually drive less than once a week, and i don't even know, the weeks all blur together in the past year and even before that, but much more since then, due to not going to the store, ordering stuff delivered, and the point is that i'm likely to forget and to not drive the car long enough. Maybe i will remember but probably not, i'd rather have a way to keep it charged up good all the time since my lifestyle is almost devoid of driving until pandemic scares die down, if ever, and more is known about what's going on. Ever since i retired, i didn't pay attention to how much i drove but i drove enough during job for a quarter century, i wasn't eager to go anywhere in traffic. I need to call around to places to get a battery and see if they have maintainers there or if i should get one on Amazon. Thanks for a solution in the meantime!
  18. bisco
    52,886
    dealer has a good battery, about 200 bucks. see what others are getting. amazon has a lot of maintainers, you don't need anything fancy, but make sure it handles agm.
    jaw444 likes this.
  19. jaw444
    jaw444 Member
    283
    27
    After getting more clear in the past few days about what might be the role of my 12V in other problems i've had, and learning the pretty dire effects of not driving it, i think i'll remember to drive it every few days now, but probably not for long enough. Still, better than nothing. thanks for telling me where to find the SKS switch. when i am ready to start it again, is it just a matter of switching it back on?
  20. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    That's exactly correct. Leave it on (out position) when driving and switch it off (in position) when it is just sitting. You will just have to use the key fob buttons to unlock the car when starting to drive and then again to lock it up when driving has finished.
    jaw444 likes this.
