New Engine, New problems: need some direction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by excellentterrestrial, Oct 17, 2021.
  1. excellentterrestrial
    excellentterrestrial Junior Member
    Hey folks! Y'all have been tremendously helpful to me in the past so I thought I'd call on you again.
    Last year with some guidance from you fine folks I replaced the head gasket in my 2011 Prius IV. It went great, but I guess she was just too far gone because a few hundred miles later I threw a rod.
    I bought another engine and started the job of swapping them out -- got the old one out, but the stars didn't align for me to keep working on it for nearly a year. We finally got the new one in and all the parts back on, new oil and coolant. Put it in maintenance mode successfully, started it and...
    Well, it ran perfectly for about 10 seconds, then shut off and threw me a yellow triangle and a check hybrid system warning. Now the ICE won't start, in normal or maintenance mode. It comes on, I can hear stuff in the inverter area spinning and clicking, but no ICE.
    I had to scoot off to work so I haven't even had a chance to check codes, just trying to think if there's something obvious to pursue here. My thoughts:
    1. Could the hybrid battery be toast from being parked so long? I had the safety plug out and the 12v disconnected (had to replace 12v bc it wouldn't charge) but a year is a long time. I would think that the engine wouldn't have cranked the first start if the hybrid battery was dead but idk.
    2. Bad gas? Has it been long enough for the gasoline to go bad?
    I have no idea where my code reader is so I won't be able to check codes til tomorrow at least, and I'll update with that info when I have it, just trying to get an idea of where to head next for this job.
  2. JC91006
    16,872
    8,619
    Just for fun, put in 4 gallons of fuel and see where that gets you.
    If the engine spun for 10 seconds, it actually never started, it's just the battery spinning it. Since this is a new engine, maybe you should try a few times (with a fresh 12v battery).
  3. excellentterrestrial
    Bet, I'll give that a shot and let you know :)
  4. JC91006
    16,872
    8,619
    BTW, did you clean the EGR and intake before putting the engine back in? Did you replace the water pump
  5. excellentterrestrial
    EGR and intake are clean, didn't replace water pump however. I'm not sure if we swapped the water pump from the old engine to the new one, but i don't think so.
    We bought the replacement engine used, so it could have had some issues we weren't told about. Everything looked solid visually though, and when I drained the oil it wasn't gunked up with coolant or anything like that.
    Gas tank is half full so I'm not sure adding fuel will help, unless my suspicion that the gas has gone off is accurate. Should I try siphoning the old fuel out and refreshing it?
    privilege likes this.
  6. JC91006
    16,872
    8,619
    I don't think gas will go bad in 1 year, it would take much longer time for gas to go bad. You can't rely on the gas gauge, best to verify visually. I've seen cars with 3 bars of gas on the meter, yet completely empty.
    excellentterrestrial likes this.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,674
    6,704
    Texas Hill Country
    Gas with ethanol can go "bad" by gunking up the fuel system. Injectors and the fuel pump come to mind. A pressure check might help there. However most engine swaps that fail to start are caused by connectors not plugged in 100% or missed all together because they are behind or under something. Codes are likely to point to most of those but you may need Techstream or one of the Pro scanners from Autel, Launch or Snapon. For example, you could have high voltage leakage at the AC compressor plug.
    #7 rjparker, Oct 17, 2021
  8. excellentterrestrial
    Updates!
    Checked codes:
    P0118 (i had failed to plug in a temp sensor, d'oh! resolved)
    P3191
    P3190
    P0403
    I added gas as per @JC91006 suggestion. Car will run for longer now but sounds rough -- might need to go through and clean these EGR parts again, just to be sure. No milky oil or stinky coolant or other head gasket symptoms at this point. I've got parts from 2 different engines I can swap out and see what's in the best condition.
    However now, after running for about 30 seconds to 1 minute, I get a Low Traction Battery warning on the display telling me to shift car into Park (it's already in park). Sometimes it'll shut off the ICE at this point, sometimes it won't. Thoughts?
    My biggest fear of course is that I'm gonna have to buy a new hybrid battery. Tbh it's worth it to me at this point to replace it rather than trying to unload this scrap heap and buy a new one, but I don't want to invest in that until I'm reasonably certain that everything else is fine
  9. JC91006
    16,872
    8,619
    If the 12v battery is marginal, you should charge it first. Don't try to diagnose with a weak 12v battery.
    There is a good chance the HV battery will be low and out of balance. For now, the codes you have doesn't show that's a problem. Have you tried driving this around the block?
  10. excellentterrestrial
    I haven't taken it out of the garage yet. My driveway's on a steep hill and I'm scared of not being able to get back up it. The 12v battery is brand new, the old one was dead and wouldn't charge. I'll see if she'll... pull out of the garage and back into it, just to give it a chance to run in drive and make sure it's shifting properly?
  11. JC91006
    16,872
    8,619
    Look at the HV BATTERY STATE OF CHARGE meter, you can manually force charge the battery to make it full. Put the car in DRIVE, with the BRAKE PRESSED, step on the accelerator at the same time. Having both brake and accelerator pushed down while the car is in DRIVE, this will force charge the HV BATTERY. Watch the meter and stop when it's full.
    If you're able to force charge the battery, then let the car run in inspection mode and see if things improve and idle a little better.
    You should not drive this out of the driveway with a steep incline, until you're able to make this car idle smoothly and have the fans turn on when it's warm. Don't want to get stuck when you're out of the garage
  12. excellentterrestrial
    Attempt to force-charge HV battery didn't go super well. Battery meter looks almost full when I start the car, then drops to 1 bar very quickly. I am able to shift into drive, and the engine is sounding smoother now when i press the accelerator, but it instantly throws up the warning that I need to put the car in park. The battery doesnt seem to be charging when I press the accelerator, and it will eventually throw the "Check Hybrid System" warning, at which point the engine will no longer start until I clear the codes. I attempted this twice, and the second time the engine continued to run without going to "check hybrid system" (though it did tell me to switch to park), but after a minute or two I saw smoke creeping out from the exhaust manifold area so I cut it off.
    There's a burnt smell coming from that area now, but it's not that foul smell I experienced with the head gasket leak. Coolant is stable. I'm just obsessively checking for head gasket/egr symptoms since we've already been to that particular circus lol.
  13. JC91006
    16,872
    8,619
    Yikes. well if the battery soc was full and it drops to 1 in a matter of seconds, then your HV battery definitely has some issues with balance (and possibly dead module).
    But more concerning is the smoke from manifold and burning smell. Yikes, wonder what could have gotten in there to smoke?
    Well you can check your codes again, see what's new. So far seems like EGR system looking pretty suspicious up and your HV battery isn't very healthy.
  14. excellentterrestrial
    Agreed, I'm not gonna be able to mess with this til next week so I'm gonna disconnect the 12v and do some research. Plan of action is to take apart the EGR system and give everything a good cleaning. Make sure I've got the best of both sets of parts in there and see if that handles the rough idle/smoking issue. If I can get it running smoothly enough to recharge the battery we'll see if that keeps acting funny.
    That seems above my pay grade to replace, but I might ask around local mechanics and see if someone will swap one for me for less than one of these little mobile battery dealers, if this one turns out to be shot
  15. AzusaPrius
    AzusaPrius Senior Member
    2,248
    935
    When you said the stars did not align, that is where your problem happend, these cars can not sit for a year.
    The HV battery will be no good but may be able to be charged with a prolong system but if not use Dr. Prius app to find the bad modules and replace them if you can if not have them replaced by someone who can.
    Once you get that fixed then go onto the egr and intake manifold again once you get it running.
    No need to do the egr and stuff if you can not even keep her running.
    Fix the HV battery.
    http://www.RedBullet.net
    https://ProjectLithium.com/?ref=mG0GE
    http://www.Pulstar.com
    http://www.PlugOutPower.com
    Use code 7373
    http://www.hybridpit.com
    Use code azusa
  16. excellentterrestrial
    OKAY SO it's been a minute but I want to update on this. I love this car dearly and am about to yeet it into the sun.
    Got in there to check on all the EGR parts and everything looks pristine. Well, not PRISTINE, but reasonably clean, we had cleaned the EGR before the engine replacement, and basically chose the better parts from the two engine assemblies to put back together. I followed my hunch about the gas, hooked up the fuel pump to a 12v battery and drained every drop of gas I could from the tank, filled it back up with premium gas.
    Ran perfect after that.
    No funny noises, no codes, no drama with the hybrid battery, put a few hundred miles on it over the next week with no issues whatsoever.
    Until.
    I went to check the fluids before a long drive and noticed my coolant reservoir was low. I immediately panicked, but then realized I didn't burp the coolant after refilling it when we put in the new engine. So I filled it back up, and got a small shudder when I started her up. Like, half a second, but I Know that sound. Drove it a little bit, shudder didn't repeat, no codes or misfires per my code reader, but i Know that sound.
    Did long drive bc I didnt really have a choice, lost maybe another quart of coolant in the process. I have not experienced any major engine shake, overheating, no CEL and no codes, but I am experiencing coolant loss and a barely-perceptible shudder/hesitation on cold start and twice when making a sharp turn.
    Could this be because I didn't properly "burp" the coolant when I added it? I'm going to change the oil tomorrow to see if it's all milky, though it looks clean on the dipstick/oil cap. Is there anything this could be other than the head gasket? If it's head gasket again I am walking into the sea lmao
    Water pump maybe? Am I possibly overreacting? I dont even know anymore y'all my brain has been mostly replaced with cuss words because of this vehicle lol
  17. rjparker
    10,674
    6,704
    Texas Hill Country
    All you can do is be proactive now. I would do a borescope and look for a stream cleaned piston. If it becomes round three on the engine, go for a rebuilt this time. Dealers and pros chose that option once it starts drinking coolant.
  18. privilege
    privilege Active Member
    659
    169
    Birmingham
    Are you shutting off the engine while it's running ? I've found that if the engine is running and I turn it off, it will consistently rattle on the next start up. If I wait until the engine has completed it's cycle, it will be silent on next start up.
    Coolant loss... May not be loss at all. Make sure you've filled and burped the air completely. You may want to use a vacuum bleeder to get all the air out.
    The suggestion to use a bore scope to view the piston is a good idea. If there is coolant leaking into the cylinders you'll find which ones.
