New engine noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bmparent, May 25, 2021.
  1. bmparent
    bmparent Member
    159
    65
    barre ma
    So this sound was first noticed a couple of weeks ago. It sounds to me like a light rattle. I'm at 182,000 miles, regular oil changes, overall a car in decent shape for it's age. The sound is coming from the passenger side, if I had to be more specific I'd say in the belt area, even more likely this because I only hear it when the engine is running. It tends to go away or at least be much less noticeable after the car is warmed up. I haven't noticed any performance issues so far. MPG pretty high, coolants full, A/C works well. I just tried to upload an audio file but the file wasn't in a format that would upload, so that's not helpful, I know, sorry!
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,622
    6,658
    Texas Hill Country
    Could be a rattle in the door. I have had it in the past. Once the car has been driving a while it would go away.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    If it is an "engine" noise, likely culprit would the the engine water pump or tensioner pulley. (bearing issue)
    bmparent likes this.
  4. Av1dreader
    Av1dreader New Member
    I'd agree. I had to replace a water pump at around that mileage, and it was such a faint noise at the beginning, the dealer didn't hear it. But exactly that, a light rattle on the passenger side.
  5. bmparent
    bmparent Member
    159
    65
    barre ma
    I'm pretty sure it's not the door, since the noise in emanating from the engine compartment. But, I can always give it another listen.
  6. bmparent
    bmparent Member
    159
    65
    barre ma
    So I take it to mean that this might be (I'm hoping) a gradual failure and not an indication that it's failed already. Is this engine coolant we're talking about here?
  7. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    Yes, engine coolant. Take a flashlight and look down in the area at the front of the engine on the passenger side. The water pump is down there. If you look carefully, you should be able to see where the belt wraps around the water pump pulley. Look at the back side of the pulley (the area between the pulley and the pump). If you are losing coolant, you will see a moist pink residue on the inside lip of the pulley. If you see dry pink residue, it has a very small leak (more like a seep) and the moisture is evaporating before it even builds up. Quite often, the pumps make noise for a while before they get to the point of actually losing a seal. Unfortunately, there's no perfect way to predict if or when it will experience failure and start leaking significantly, or at all. I bought a 2008 in Myrtle Beach several months ago with a noisy water pump bearing and an ABS code for linear valve offset unlearned. I bought a gallon of coolant and put it in the back seat just in case and then drove home to Columbia. Noisy like crazy, but didn't lose a drop of coolant. Installed a new pump the following weekend and noise is gone. Now I just have to fix the ABS.
    Until you can replace the pump, just keep an eye on the coolant reservoir located on the engine side of the radiator. Use a good flashlight and you can see the coolant level through the plastic.
    #7 TMR-JWAP, May 26, 2021
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,100
    2,002
    NJ-USA
    Often when (if) the water pump bearing starts to fail, it will result in "looseness" - ie, you can pry gently on the pump pulley and it will rock or wobble.
  9. bmparent
    bmparent Member
    159
    65
    barre ma
    Super helpful, thanks. There is some dry residue on the front of something, I don't know the part, it's actually been there quite a while. My coolant reservoir is still very full though. I haven't got any engine codes yet but I do think I'll bring it to the garage in the next couple of weeks for a check-out.
  10. mr_guy_mann
    4,100
    2,002
    NJ-USA
    Just make sure to check the actual level in the radiator from time to time (when the engine is cold).
  11. bmparent
    bmparent Member
    159
    65
    barre ma
    That's a good point, I don't usually do that but I'll check.
