New Entune update changed defaults?
Discussion in 'Prime Main Forum (2017-2022)' started by ttait, Jun 5, 2018.
  1. ttait
    ttait Active Member
    273
    163
    Southern California
    So, like probably most of you, I received an Entune update the other day.
    Some of my defaults seem to have changed and I can't figure out how to change them back. And I'm usually pretty good about this stuff.
    Of course, all my apps changed positions, this happens every update and is expected and, while easily fixed, is just plain annoying.
    What is bothering me the most with this update is that the screen now defaults to showing the silly round menu items at the bottom instead of just the map. I prefer just the map, if I want to see the 'menu balls', I'll hit the button.
    I can't find a setting to return the screen to just showing a map on startup. I know I can just drag them down, but I don't want to do this every time I start the car. So if you know, please share.
    Of course, I don't ever want to see 'Insufficient Connectivity' again, and the lack of true LKA, and support for Siri but not Google assistant, or the remote climate fail yet again, either, but I guess I have to pick my battles. But I am getting tired of losing so many battles. Just got a Volvo for the wife, terrible mileage on premium gas (compared to the Prime), but a true pleasure to drive. And Android Auto just works. And Waze. And Pandora works every time.
    I like the handling of the Prime, and I regularly get well over 1000 miles/tank, but these small frustrations are starting to make me reconsider my choice. A BEV is starting to look better and better. Which, as an early adopter, makes me sad.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Page 16 of the 2018 Navigation Manual PDF says there is an icon/button in the left upmost corner of the menu screen that toggles whether the round menu balls are displayed. I don’t know for sure if they stick across power cycles.
    J
    ttait likes this.
    52,880
    i can't believe you're on your 3rd prius and this surprises you.:p
  4. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    Have not received the update notice yet...but then I am only driving a mile or less each time to try to trick it.
  5. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    We have the base model (SMALL SCREEN) no update for us!
  6. breakfast
    breakfast Active Member
    266
    199
    I got an update with the small screen yesterday. Sound quality appears improved for some strange reason on my Prime Plus ¯\_(ツ)_/¯
  7. ttait
    ttait Active Member
    273
    163
    Southern California
    Found the button, thanks. Don't know why a software update makes it lose it's memory. It doesn't forget it's map.
  8. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    Well maybe it's like updating the firmware in a router. Usually the settings stay but occasionally the change doc says "reset to factory defaults" after the update.
  9. Mark57
    2,945
    2,740
    OK
    On your phone, connect to WiFi or your data plan. Then with the car in ready mode or running, connect to the car with BT. This should auto launch your entune app and updates will be detected and prompt you to download. It's not much data, but if you're tight on data, use WiFi.
    Read the screen prompts. It tells you exact what it's doing and what's being installed.
  10. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    Nothing outwardly changed on my Prime Advanced after the recent update a few days ago.
