new evidence that ECO mode works
Discussion in 'Gen 3 Prius Main Forum' started by mainerinexile, Feb 23, 2011.
  1. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    There are many posts describing that ECO mode lets the CC vary the speed a bit for better gas mileage, and when in ECO mode, we have all experienced the A/C fan speed drop when the car is stopped, again to let the car run more efficiently.
    I discovered a new way that ECO mode works if AC is not in use: when the car is warming up in cold weather (i.e. the first couple of miles), going into ECO mode causes the heater fan to drop in speed by two bars. The car is keeping the heat in the engine rather than the cabin, so that the engine gets up to temperature more quickly. Getting out of ECO mode causes the fan speed to increase by two bars. When the car is warmed up, this effect doesn't happen any more.
    3 people like this.
  2. jdimetal
    jdimetal New Member
    52
    Fredericksburg, VA
    I have noticed this as well
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    When AC is in Auto, the fan speed is at one bar till about 103F coolant temp (outside temp @ below 20F). Once above that the fan speed slowly increases as the temp rises.
    So yes, your observation is quite right.
  4. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    ECO definitely scales back the HVAC/Defrost/Fans, no doubt about it.
  5. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    I can't remember the last time I had my car out of ECO mode. I've mentioned on various occasions how it helps in slippery conditions. I've notice the above as well.
    All in all, I think keeping it ECO has saved a lot of fuel; it's a great addition to the Gen III.
  6. Sporin
    Sporin Prius Noob
    576
    293
    Vermont, USA
    I mostly leave mine in ECO as well. On really cold mornings where I'm trying to warm up the car, defrost the windshield, and keep the breath of 3 people from fogging up the windows, I will sometimes put it in power mode though. Power (or even Normal) definitely keeps up with that better. I can give up a bit of efficiency for sight and comfort over the first few miles of my travel, that's for sure. :)
    Once everything is warmed up and the windows are clear and we are moving along I go back to ECO.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Other than a brief trial in the other modes when the car was new, I too have never used anything except ECO mode.
  8. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    So the ECO details are starting to come out. Good to hear! As opposed to the constant statement, "its just fuel mapping". Blah, blah, blah. Still, it would be nice to see all the little details of ECO listed somewhere.
  9. DanMode
    DanMode Brooklyn Prius Guy
    98
    Brooklyn, NY
    Aside from when first driving the car, I don't believe I've used ECO mode much at all. I'd say 95% of my driving is in Normal, 4% would be in PWR Mode and the only time I'd really use ECO mode was when I was driving on a driveway made straight of ice and had to back into a garage. The ECO mode sensitivity combined with the hill start assist really helped out in that regard. :)
    I'm happy to see people getting good use out of ECO mode, but with my driving style it just doesn't cut it for me. I'm more of the 'get up to speed' and then glide sort of guy.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    ^ if you are getting 52.5 average in those other modes, who cares about ECO! :)
  11. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    For those of us who regularly use adaptive (or even normal) cruise control, having some sort of confirmation that ECO mode relaxes some of the gain would be very useful. It's a very difficult thing to test empirically because it's just too hard to control all of the parameters (temperature, slope, wind, traffic).
  12. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Here's ECO mode info from the 2010 Prius Technical Overview doc (attached below):
    B. Driving Modes
    1. Eco Mode
    a. Maximizes fuel savings across all driving conditions
    b. Modifies or smoothes out the electronic throttle control
    program to reduce throttle response
    1) Reduces throttle opening up to a max of 11.6%
    c. Modifies air conditioning operation
    d. Also improves acceleration performance in low-traction
    conditions like ice and snow as the reduced output
    helps to minimize wheel slippage
    e. EPA label calculations do not include Eco Mode and so
    does not affect label mpg
    2 people like this.
  13. dkelly
    dkelly Member
    118
    Gilbertsville, PA
    Thanks for the data. I will be sure to read over the entire document. Of course, this doesn't make any mention of cruise control operation. Slowing the throttle response would of course help in any mode of operation (manual or cruise).
  14. tumbleweed
    4,067
    687
    Eastern Oregon
    I am curious about the effect of ECO on CC operation also. I think from my observations the CC maintains a constant speed even on hills no matter which mode you are in. But ECO could modify the acceleration to resume to a preset speed, it might be possible to test that.
  15. Mendel Leisk
    38,718
    I've been using ECO basically all the time. Still, just just thinking aloud:
    Maybe it promotes leadfootism, ie: you adapt to the very sluggish response, by tromping down further/harder on the gas?
  16. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I use ECO all the time, and in heavy snow (on my short non-maintained road) I find wheel slippage is further reduced by driving in B mode. Ihave no technical proof other than the lack of the traction control engaging in the same spots all the time.
  17. Iwannabeahippy
    Iwannabeahippy New Member
    Michigan
    I am curious about this too. Good suggestion, actually. I just bought an end of year 2010 II last week, and after watching all of the YouTube videos about no power to the wheels if they slip scared me. I will try this if I have driving problems.
    Thanks!
  18. mainerinexile
    403
    73
    Maine
    I either read it here or in the owner's manual that ECO mode allows the CC to let the vehicle speed vary by an additional mph, which would be a good thing for hills. Not sure I've seen this in action though. CC will kill gas mileage on hills, so I usually disable it then.
  19. mainerinexile
    403
    73
    Maine
    Item c. says that ECO mode 'modifies A/C operation', which we all knew. This is the reason I was surprised to see the effect for heat, when A/C wasn't on. And unlike A/C, the effect for heat is temporary, only when the engine is warming up. The list needs this additional item, plus one for CC operation in ECO.
  20. mainerinexile
    403
    73
    Maine
    Don't worry about slippage as long as you have appropriate tires for the conditions. The number of people pleased with winter performance in the 2010 outnumber those who have complained by 10 to 1 or more! Mine has been great in the snow. In fact I take the Prius instead of the 4WD Tacoma in bad weather, because of the low center of gravity in the Prius, and the inherent light rear end in any pick-up which causes them to spin out from the rear.
