"New" Gen 3 prius with busted HG
Discussion in 'Gen 3 Prius Technical Discussion' started by Melthias, Jun 17, 2023.
  1. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    It should be by now.... Maybe sticking thermostat? Glogged hose?
    Blocked radiator?
  2. Melthias
    Melthias Member
    110
    37
    Southern Maine
    Sorry it has been a while, I resolved the water pump issue. I had been using the water pump that came with the newer engine, but upon putting in the one that originally came with the car all of my problems went away. I hear that usually the actually circuitry in these pumps doesn't go bad, but I guess this was an exception.
    ASRDogman likes this.
  3. Melthias
    Melthias Member
    110
    37
    Southern Maine
    This car (the silver fox) has been running like a champ, and other than a wheel bearing and spark plug seals it has needed very little since I bought it 16mo ago. This past summer I bought a 2011 prius (190K) with a blown engine and replaced that with another JDM. That project cost about $4000 total, and it went to a friend in dire need of a first car. About a month ago I found a 2012 Plug in Prius with a blown headgasket (250K) and bought it for $1400. I am interested in trying to get this car going and to eventually replace the silver fox. I am trying to assess what I might be able to get for it.
    I have undercoated it each winter, and have used a grid charger at least every summer. There are little scratches, but no large dents or issues on the outside, and no visible body rust (topside). It had a new 12V battery when I got it, and has had 5K oil changes since I bought it. The engine had "less than 70,000mi" on it, so if you believe that the engine is now 90K. It now has 250K on it, and has not had any notable MPG decline other than the usual seasonal variation, including a significant decrease when the snow tires get put on.
    Kelley Blue Book says $4,200-$6,550
    JD Power says $5,967 - $7,133 from a dealer
    I just do not know if these are realistic values or not. I put in $6000 total on the silver fox. It would be great to recoup that, along with some extra cash, but obviously it is only worth what someone will pay for it.
    Anyone have any thoughts on what to try to get for a prius in great condition with a newer engine in it?
  4. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    And No...... Inveter, Brakes or Traction Battery problems?
  5. Melthias
    Melthias Member
    110
    37
    Southern Maine
  6. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    That's pretty rare..... hopefully they were raplaced before you got the cars
  7. ASRDogman
    8,066
    4,089
    You never REALLY know how many miles on that used engine. Or where it really came
    from or out of.
    The prices aren't realistic any longer. That's why there's such a huge range.
    It's likely going to need a new hybrid battery before too long. And might be needing
    the brake master cylinder and pump replace in the near future. You can get an idea
    for that by how long between cycles.
    Doubtful you'll get you're money back, but you never know. Don't forget to count
    YOUR labor you've put into it...
    Tim Jones likes this.
  8. Melthias
    Melthias Member
    110
    37
    Southern Maine
    This seems contradictory. I would love to count my labor, but I spent at least 40hrs getting this car ready for the first inspection, which at $20/hr is $800 (as I handyman I charge more in the $50-$60 range). As I say, I would like to get a bit more than I put into it, but $7000 may be too much for the market.
  9. ASRDogman
    8,066
    4,089
    So your time is worthless? $20 an hour for labor??? NO car place is that cheap.
    Likely the best you'll do is maybe break even.
  10. rjparker
    rjparker Tu Humilde Sirviente
    11,108
    6,970
    Texas Hill Country
    High miles are working against you regardless of the engine.
    I would private sale it starting at $6k and take $5,500. I would include the replacement engine in the ad as a plus. If it does not burn oil, mention that as well. A 90k engine should not burn any noticeable oil in 5k miles.
    No negotiation on the phone. Most of those guys will be used car dealers. If the car looks good and runs and drives it will sell. Don't expect a one day sale but I could sell it in ten days down here.
    Have an as is bill of sale ready, no checks unless it's a bank check created with you at the bank. For this amount a buyer could bring cash. Get a copy of their insurance and drivers license. In most states there is an online method to report the sale.
  11. Melthias
    Melthias Member
    110
    37
    Southern Maine
    No, my time is not worthless, but under these circumstances it seems unlikely that I will get those hours paid for at all regardless of the rate.
    This is good advice, thank you! If we do end up deciding to sell I will report back how it went. Before I post it for sale I would at least like to make some headway on the plug in.
  12. Melthias
    Melthias Member
    110
    37
    Southern Maine
    I ended up selling it to a friend. He had just gotten screwed on a used Tacoma from a shady guy, and was looking for something that was a turnkey solution. He flew up here and we did an oil change and oil catch can install together. I bought him a scangauge and taught him how to use it. I had removed the catch can and scangauge to my "new" 2012 plug in with a JDM engine in it. He paid me $7000 for it. He knows that I am a meticulous person, and I have gone through everything with that car, getting it running in as tip top shape as is possible. His girlfriend has a Gen 2 that is on its last legs, but has a pretty new HV battery in it. I think that when they are done with that one they will swap the battery out.
  13. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    I would never sell a gen 3 to a friend.....................
