New GenIII brake recall affects 87,000 cars
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by DavidA, Jun 5, 2013.
  1. walter Lee
    1,126
    376
    Maryland
    Thanks for the heads up. Found that my car isn't part of the the recall.
    Wrt to tire overinflation - I've dropped mine from 50/48 psi to 44/42 psi over the last two year because I couldn't achieve any significant FE improvement at the higher pressure setting. My personal experience has been that local wet and/or rough road surface conditions negated most of tire over inflation's fuel efficiency advantage (between 15 to 40 mph when rolling resistance does matter most for FE ) at the higher psi settings for my OE Yokohama Avid s33 tires .
    F8L likes this.
  2. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    About time, I had two total brake failures until both my master cylinder assembly and accumulator were replaced.
    cwerdna, bwilson4web and F8L like this.
  3. bwilson4web
    16,189
    I'm sorry I missed this. Did you post a thread about it?
  4. Former Member 68813
    3,524
    983
    US
    Can people with recent total brake failures confirm if their cars were built before October 2009, please?
  5. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    My car is included in the recall, confirmed by Toyota from their very helpful "email us" page Toyota Email Us
    Aussie PriusChatters can read the recall details here: Toyota—Toyota Prius ZVW30
    PRA number: 2013/13622
    Date published: 7th June 2013
    Product information
    Product description
    Toyota Prius ZVW30 - Brake Booster Pump Assembly (Accumulator)
    Identifying features
    From VIN - JTDKN36U#
    01000031 - 01092008
    05000003 - 05076028
    Production period from October 2008 through to October 2009
    (Please refer to VIN table attachment)
    Feri likes this.
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Thanks for the links Braddles! confirms what my dealer told me.
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Finally! Safercar.gov finally has the recall and some associated documents: 3, for now.
    The NHTSA campaign # is 13V235000. Not much new info in the text outside of the PDFs other than
    http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM439340/RCAK-13V235-4933.PDF
    http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM439361/RCAK-13V235-8848.PDF
    http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM439269/RCDNN-13V235-2333.pdf
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I like the NHTSA remedy better than the one on the Toyota Owner's website. The Toyota website states the remedy is "for the dealer to inspect the brake booster pump assemby and replace if necessary". The NHTSA remedy drops the inspect and replace if necessary part and just says replace.
    I hope this is correct.
    spiderman and bwilson4web like this.
  9. bwilson4web
    16,189
    I agree "replace" as metal fatigue on the bellows would be very difficult to trust in even a well equipped, service department.
  10. Feri
    Feri Active Member
    761
    144
    The Australian one says replace if necessary too. I definitely will try to convince my dealer to replace no matter what.
  11. Former Member 68813
    3,524
    983
    US
    It actually says "replace the affected brake booster pump assemblies". I think by affected they mean defective. Maybe they know what serial numbers are defective?
    jdcollins5 likes this.
  12. Former Member 68813
    3,524
    983
    US
    No one did, so I went ahead and PMed all 11 members that complained about total brake failure in 2010 Prius on this forum. Only 5 responded back, and while 1 didn't know when his prius was made, 4 other ones reported their prius made before october 09. I can't help but think that the recall is connected with the total master cylinder failure incidents. I think Toyota downplayed the extent of the problem in the public release.
  13. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Dumb me :( I told my wife about the recall, then she asked me how safe the car is to drive on a trip to MI we're planning. She's already afraid to drive the car (it's too complicated!) because I tried explaining how the system works, instead of just telling her it drives "normally." So far I've not noticed any problems with braking, although my Prius is part of the recall.
  14. michinnom
    michinnom Member
    162
    29
    Here's what I saw when I logged into my toyota owners site today:
    DESCRIPTION
    CUSTOMER MESSAGE
    CAMPAIGN NUMBER
    Safety Recall D0H (D1H) Preliminary Notice - Certain 2010 Model Year Prius Vehicles Brake Booster Pump Assembly (Accumulator)
    At the present time, Toyota is currently preparing the remedy.
    What is the Condition?
    The subject vehicles are equipped with brake pressure accumulators consisting of a metal plunger containing brake fluid encased in a metal housing. The plunger is designed with metal pleated bellows to allow for motion. Nitrogen gas is sealed between the plunger and housing. There is a possibility that a fatigue crack could develop in the bellows due to the vertical vibration of the plunger while driving. If this occurs, nitrogen gas could leak into the brake fluid and cause the brake pedal stroke to become longer, resulting in decreased braking force. Decreased braking force could result in increased stopping distance and increase the risk of a crash.
    When will the Remedy be Available: The remedy procedures will be provided to each dealership in the near future. At which time, Toyota will notify owners of covered vehicles by first class mail. Additional information will be posted on this site once the remedy is available.
  15. Braddles.au
    295
    99
    Canberra, Australia
    Would she prefer to drive a Jeep?
    WE0H and bwilson4web like this.
  16. jdcollins5
    5,131
    1,346
    Wilmington, NC
    This is what I read from the Toyota Owner's website about the Safety Recall and the FAQ section:
    Q3: What is Toyota going to do?
    A3: Toyota is currently preparing the remedy for this condition. Once preparations are complete, Toyota will send an owner notification letter by first class mail to owners of vehicles covered by this Safety Recall.
    When available, the remedy will entail an inspection and, if necessary, replacement of the Brake Booster Pump Assembly at No Charge
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes, I have the same message at the owner's site. I see this as a good thing, I am glad Toyota is trying to fix this before someone is injured or worse. I will schedule my car as soon as I get the notification.
  18. Former Member 68813
    3,524
    983
    US
    Edit: My post makes no sense now, Did we merged some threads here?
  19. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    My 2010 Prius bought July 09 is one being recalled. A check of the Toyota owners site told me my car was one of the ones needing the updated part. I seem to remimber they said the Prius built from Early 09 through about October had the old part, about 87,000 US models.
  20. FireEngineer
    1,247
    124
    No I didn't Bob, I had enough problems trying to get three different dealers to fix the brakes. All-in-all my Prius was in some dealer shop for a total of over a month. And come to think of it, it was 3 total brake failures. B-mode is your friend.
