New guy with a couple of questions
Discussion in 'Gen 3 Prius Main Forum' started by Steelholder, Oct 25, 2022.
  1. Tombukt2
    Tombukt2 Senior Member
    12,866
    2,314
    Durham NC
    So they must've been 20 to begin with I guess
  2. Tombukt2
    12,866
    2,314
    Durham NC
    If you can find the shop that still has the original safety Kleene green solution. That is the stuff although it's not been available for some time you cannot put your hands in it It will eat them up but boy does it clean metal parts come out silver and beautiful. Of course regulations took that cleaner out of the business safety clean is still in business but that fluid that they use there's no longer they've had to go green and what have you like all the laundry detergent brands and everything else now you're not allowed to clean.
    Steelholder likes this.
  3. Steelholder
    Steelholder Junior Member
    73
    17
    Encino
    Looks like I should wait for thr pcv valve then. I'm not too concerned with having a very clean manifold ill give a good brushing but that will be it. What I really care for are clogs in the egr ports and pipe. By the way, this all preventative, the car runs perfectly fine, just wanna take care of any potential problems.
  4. Mendel Leisk
    41,222
    There's a typo in that link (reported just now); the correct name for the product I used and recommend for cleaning the cooler is:
    Oxi-Cleaner Versatile Stain Remover
    That's the way to do it. A lot of people do the opposite, leave it past 100K, 150K, and then go on a cleaning spree, when the cold-start shakes start. Trying to turn back the clock.
  5. Steelholder
    73
    17
    Encino
    Can anyone here source the bracket for the OCC used in Nutzabiutbolts YouTube vid? I knows there's many ways to attach these but I'd like to follow his tutorial if possible. I don't have a 3d printer.
  6. Mendel Leisk
    41,222
    Lots of ways to cobble a bracket. Here’s what I used (with single can), needing an L-shape bracket for on top of lower cross beam. I just added slots up to the edge, so I don’t need to fully remove mounting bolts, just loosen, then lift the can up and off.
  7. Tombukt2
    12,866
    2,314
    Durham NC
    I would think online automotive tank mounting brackets. The jig Mendel bent and drilled up is great type of thing . I think online you'd be able to find similar to that and many colors made out of aluminum blah blah blah just because that's why a lot of this stuff exists just because.
  8. Mendel Leisk
    41,222
    Google this:
    automotive cylinder support bracket
  9. ASRDogman
    ASRDogman Senior Member
    7,519
    3,889
    I use Bosch plugs from autozone.....
  10. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Legitimate Denso plugs were $8.95 apiece (plus shipping) from McGeorge Toyota when I ordered them in July. Any lower prices are likely counterfeits, especially if from e-bay.
    Foxglove and Steelholder like this.
  11. Steelholder
    73
    17
    Encino
    Collage_2022-10-29_18_37_44.jpg Collage_2022-10-29_13_14_18.jpg Well couldn't get any real work done so I decided to replace the headlights and wrap the spoiler and give it a good wax.
    TGrracie, Montgomery and Noahdoge like this.
  12. Steelholder
    73
    17
    Encino
    Alright guys, I added the the occ and pulled the manifold to see how clogged the egr ports were, not bad at all, didn't even bother trying to clean them. The egr pipe wasn't clogged at all either. I didn't pull the egr or the cooler but I think it's safe to assume they're OK too.
    I replaced the PCV valve and the plugs, put everything back together and it threw 2 codes - P0102 and P0113. I rechecked everything and noticed I hadn't reconnected the maf sensor, I reconnected and cleared the codes but they keep showing up on the Dr prius app using a wireless obd. They don't show up on the dash as a check engine light (drove it around 5 miles) and they don't show up on my wired obd reader. Do I need to drive a good amount for those to clear from the Dr prius app?
    #72 Steelholder, Nov 4, 2022
    Foxglove and Mendel Leisk like this.
  13. ASRDogman
    7,519
    3,889
    You might have to drive it for a while before the codes clear.
  14. Mendel Leisk
    41,222
    I’d left something disconnected, maybe MAF, and it took about 5 start ups to clear.
  15. ChapmanF
    18,003
    I powered up with my MAF sensor unplugged once, and I put up with a P0102 permanent code for something like a year before Elektroingenieur kindly posted the confirmation driving steps that weren't in the edition of the repair manual I was looking at. (Another reason it's good to look at the repair manual online: always up to date. Toyota Service Information and Where To Find It | PriusChat)
    As it turned out, the day Elektroingenieur posted that was a few days after I had made a long drive out of town where I happened to hit all the right conditions in the confirmation pattern, so the code had just cleared itself by the day I read his post. If it hadn't been for the pandemic. it wouldn't have taken me nearly as long to make a drive that hit the right conditions.
  16. Steelholder
    73
    17
    Encino
    Thanks, I see steps 11,12 but not 1-10
    #76 Steelholder, Nov 5, 2022
    Foxglove likes this.
  17. Steelholder
    73
    17
    Encino
    Anyone out there have these steps or do I only follow these last 2?
  18. OptimusPriustus
    OptimusPriustus Active Member
    332
    141
    Finland
    Why it looks like the egr passages are completely clogged?
  19. Mendel Leisk
    41,222
    If you're talking about the intake manifold EGR passages, it looks like there's a light shining in, at the EGR entrance.
  20. Steelholder
    73
    17
    Encino
    actually the complete opposite, I shined a light through to show how clean or clogged they were.
