New head gasket replacement video from Gasket Masters
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Nov 21, 2019.
  1. Mendel Leisk
    41,873
    Worth a watch:
    Montgomery, ericbecky, RMB and 5 others like this.
  2. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    Nice video
    iPhone ?
  3. Mendel Leisk
    41,873
    Here's the older video, covers some things that aren't in the new video:
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Those might have been the mobile mechanics @SFO watched live:).
    Said they were in and out in 2 hours:whistle:.
    Not a bad gig for a days work(y).
    Gasket masters, RMB, m.wynn and 2 others like this.
  5. Mendel Leisk
    41,873
    Daughter hinted at the end, that they seem to be doing a LOT of Prius.
    John A, m.wynn and Raytheeagle like this.
  6. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Probably doesn’t need another day job ;).
    He probably makes s pretty comfortable living doing what he’s doing(y).
    John A, m.wynn and Mendel Leisk like this.
  7. Mendel Leisk
    41,873
    At 18:50 (of the video in first post) he describes the socket for removal of the head bolts as "size 12 triple-square". The Repair Manual calls for "10 mm bi-hexagon". I believe the latter is correct.
    Head bolt removal:
    Gasket Masters' recommendation will work, it's close, but not ideal: it's points are a little too "sharp" (90 deg vs 60 deg), and the points a little more protruding (if I'm not mistaken, hard to find info). They do get the sequence right: when removing bolts, start from the outside and work inwards, and when installing from the center, work your way out.
    Head bolt install, note sequence is reverse of removal sequence:
    Subsequent to above, tighten all bolts further, in the same sequence, first 90 degrees, then a further 45 degrees.
    One source for the 10 mm bi-hex:
    (AdBlock will hide the above.)
    #7 Mendel Leisk, Nov 22, 2019
    m.wynn likes this.
  8. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    ^^^ Added the PDF to my Prius Documents.
    Hoping I would never need it:)
    I have seen another video from these guys. I recognized their voice. I think that video was linked by Mendel as well.
    It is so obvious that these guys done so many of these. The job seems like an oil change to them.
  9. iskoos
    415
    254
    Orlando, FL
    A Question about the crankshaft pulley bolt removal. I liked the way that they showed a method for guys who may not have an impact wrench.
    But one thing confuses me, HOW ON EARTH you briefly crank the Prius engine? The darn thing controls everything by himself. We have no control over when the engine is gonna start, when it will stop, how long the crank will last etc.
    Just curiosity...
  10. RightOnTime
    790
    1,660
    183
    Kidnapped in OC, CA
    It may be possible if you disconnect the spark plugs or fuel injector harness.
    iPhone ?
  11. Mendel Leisk
    41,873
    I "think" the engine crank was done when everything was still connected, at least all the stuff vital for engine running. I'd think his assistant put foot on brake, pushed start button, and 15 seconds or so later the engine kicked in. A split second or so: he pushed the power button a second time, to kill it.
    Maybe less excitement, and if possible: cobble some kinda flat bar with holes in it, space to coincide with the pulley wheel openings. Put bolts through, locked in those pulley holes, then rotate till the end of the flat bar is lodged against the ground. Maybe.
    Similar is done to break loose the nut at the end of the drive shaft, flat bar(s) locked on the wheel lugs.
  12. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    I like how they ripped out every harness clip, used a metal razor blade on aluminum surfaces and didn’t degrease any of the surfaces before applying RTV. Oh, and they smeared on RTV instead of applying a bead.
    But for what they charge, what can you say?
    Bill Norton and RightOnTime like this.
  13. ASRDogman
    ASRDogman Senior Member
    7,796
    3,976
    MMM.... just jerk and yank on hoses... no big deal if they break or tear...
    Should have cleaned the silicone off BEFORE installing the head so it doesn't fall inside the engine.
    Aren't you supposed to put a dap of silicone on a few spots on the block before the
    head gasket goes on, or after???
    Just remember, it ain't THEIR engine! So things don't matter, just jerk it around.
    It's good to see the things you need to take off and the order. It would be smart to be more
    careful of the handling of wired and hoses. And do a better job of using the silicone.
    Also, will the clip that holds the piston back on the timing chain tensioner fall out of the
    way after tightening it up? Or do you have to unclip it?
    The video cut off before all the noises went away. DID THEY? Or did they NOT?
    That is the question! (n)
    #13 ASRDogman, Nov 25, 2019
    The Critic likes this.
  14. Mendel Leisk
    41,873
    Maybe they did, who knows. At any rate, you can. The form-in-place gasket tube instructions recommend to prep the surface I'm sure?
    I'm not so sure that's bad. It runs contrary to the Repair Manual instructions, but maybe that instruction is preferred by the engineers and draftsmen, simply because it's less ambiguous, easier to describe*. But other than that, who's to say it's better?
    The way he applies it, rhythmically putting dabs, every half-inch or so, is very hard to describe and quantify, but would I think be easy for hand application. Then he smears it, blends the dabs, and if he feels/sees a thin spot applies a little more, then blends again. Again, harder to describe in the Repair Manual, but easy and more controllable in practice?
    * I recall in my drafting days, doing a stair layout: stair came off a platform, down a flight, then turned 180 degrees outward, away from the platform above, and went another flight to grade. The engineer (a very bright guy who REALLY came up through the ranks), suggested I turn the stair the other way, doubling back towards the platform above, going under it (there was enough headroom), on the run down to grade.
    The reason being, there was nearby road, and the further out the stair jutted, the greater the risk of it getting hit.
    I went along with his suggestion, but joked that maybe it'd be better to leave it as-is, just because it was easier to draw, that turning it towards the platform I'd need another plan view, cut lower than the platform.
    #14 Mendel Leisk, Feb 9, 2020
  15. Mendel Leisk
    41,873
    Maybe they also do some head rebuilding. Here he's demo'ing a home-made valve spring release tool:
    Abel Solis likes this.
  16. ASRDogman
    7,796
    3,976
    You can buy a spring tool for about $20.00
  17. Mendel Leisk
    41,873
    Yeah I've watched @NutzAboutBolts demo of the tool, but I'm always intrigued by something cobbled together, by someone in the business.
    NutzAboutBolts and Raytheeagle like this.
  18. ASRDogman
    7,796
    3,976
    It's a nice tool. Needs some tuning, but a nice tool.
    He copied the idea of the one that has hooks the go under the cam shaft.
    #18 ASRDogman, Feb 10, 2020
  19. The Critic
    3,193
    2,333
    CA
    The purpose of a bead is to allow for an even film to be created when the two surfaces are squeezed together. If an individual can "spread" an even coat without thin spots then the same purpose can be accomplished. However, IME, squeezing a bead (~3mm) is definitely the best way to accomplish this consistently with each repair.
    m.wynn, Raytheeagle and Mendel Leisk like this.
  20. Figster10
    Figster10 Member
    207
    61
    Sacramento
    With the head on and engine on car and instructions manual in hand why Is it so hard to lock timing chain tensioner? I get little slack but I'm scared if I do everything without locking timing chain tensioner I could screw myself when i put everything back together
