New head gasket replacement video from Gasket Masters
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mendel Leisk, Nov 21, 2019.
  1. Mendel Leisk
    41,463
    Head gasket replacement video by Sane Auto, just watching:
  2. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    Mendel, what's the distance center to center on those holes? Sounds similar to the crank holding tool they sell for 1uz-fe crank bolt removal ($45).
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    Is it worth two hours and 17 minutes?
  4. ASRDogman
    ASRDogman Senior Member
    7,597
    3,916
  5. Mendel Leisk
    41,463
    I got about halfway through it yesterday. It's definitely thorough, and closer to the reality of a DIY'r, say compared to the Gasket Masters videos. The guy is a pretty experienced mechanic, comfortable with an arsenal of tools, and I get the sense it's not his first Prius head gasket. I'll definitiely be watching the rest.
    There seems to be an increasing number of such videos available, and I've got lots of time. This one's a little less "flashy", more content and thorough. :)
    Which holes? I'll take a wild stab: the threaded holes on the beltless pulley at end of crankshaft, that has to come off before the timing chain cover can come off? I cobbled a jig for that, just thin wood with a couple of 3/8" holes to see if I had it right, and c/c of those holes is 85 mm.
    #45 Mendel Leisk, Oct 25, 2021
  6. ASRDogman
    7,597
    3,916
    It's a pretty good video. Except for the noise of people banging on instruments, and the thumbs up and subcribe things
    popping up and the stupid upside down car at the top.
    I HOPE he put in a new oil filter... :)
    I wished he would have filled up the oil and coolant and started it up though....
    #46 ASRDogman, Oct 25, 2021
  7. Mendel Leisk
    41,463
    'Nother video, mercifully shorter. All of these seem to come at the job from different perspectives, but there's always something to learn:
    This one a case of the "the operation was a success, but the patient died": he got to the head gasket, but found cylinder walls badly scuffed.
    Paul E. Highway likes this.
  8. slalomboi
    slalomboi Junior Member
    Seattle
    320k+ miles on my 2010 and I have the Death Knock with coolant leak and trying to save the vehicle.
    Looking for recommended repair shops in the Seattle area, please :)
  9. slalomboi
    Seattle
    I'm not finding those head gasket videos by Gasket Master that you refer to.
    Any way one of you could share links to them, please?
  10. ASRDogman
    7,597
    3,916
    1.25, or 1.5, or 1.75, or 2.0 speed. Impossible to watch anything anymore unless it's faster...
  11. jan jurnecka
    jan jurnecka New Member
    tucson, az
    I
    maintenance mode
  12. DItd
    DItd New Member
    Bethel, ME
    Mendel, thank you for all your informative posts. I like others have been inspired by the GM video to do my own HG replacement on my 2010 Prius with 218K. I am sorry the video is now longer up. Is there a link to the new video or other videos that are instructional? I am particularly concerned about all things related to the timing chain and cover. Access to the shop manual would be much appreciated.
  13. Mike from Merrick
    Mike from Merrick Junior Member
    32
    New York
    I also thought the video was well done/explained. The jig you mention, any pics of that? Thanks!
  14. Mendel Leisk
    41,463
    Here I posted some info:
    Mechanics: what are your most common tools? | Page 15 | PriusChat
    I'd consider ChapmanF's comments (directly after) valid as well: the traditional pulley restraint looks something like this, and it's much more versatile, can fit a wide range. Something like this:
    All said, with this beltless pulley, might be one time to cheat. You can break the bolt loose with an impact, maybe when reinstalling, just make sure no one's looking, and "torque" it with the impact, say 3~4 chugs.
    #54 Mendel Leisk, Jan 11, 2023
    Mike from Merrick likes this.
  15. Paladain55
    404
    164
    The South
    There is more on the internet.
    Try one of these:
  16. Mike from Merrick
    32
    New York
    Awesome! Thank you! Now going to attempt the EGR fix, including new EGR, and PCV with cleaning all of the parts. Using Toyota parts, may video some of it. Car has 314K
    Thanks again
  17. Mendel Leisk
    41,463
    See first two links in my signature.
  18. Mike from Merrick
    32
    New York
    Thank you for your info! Completed the job, left off that stud and nut, seems reasonably sturdy without it. Changed plugs, cleaned manifold (never seen oil like that accumulate) and 3 days on the cooler. Zipped it up, only thing left is to clear the MAF code, which seems to happen at times according to the threads.
    315K miles on this former taxi, and loving the car!
    CR94 and Mendel Leisk like this.
  19. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Was that the first EGR cleanout on that car? Original head gasket? How's the oil usage? We had someone here recently claiming these engines never go over 300k without head gasket failure.
  20. ASRDogman
    7,597
    3,916
    Will turn 292,000 miles today..... Original head gasket...
    Mendel Leisk and Bill Norton like this.
