New headlight assembly sucks
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Old fat fireman, Sep 1, 2023.
  1. Old fat fireman
    Old fat fireman New Member
    Connecticut
    Replaced my hid headlights with new standard lights. Of course I bought reasonable priced units $120 set. What junk totally optical nightmare. Just because it looks the same as the others....worthless, you can't even adjust them in the ballpark.
    Need to buy new ones Again
    Any recommendations on brand other than Toyota?
  2. theory816
    theory816 Member
    112
    23
    did you replace the entire headlight unit or just the bulbs?
    Lights shouldn't be much of a problem if you do alot of city driving at night. Its really a problem on highways or places without much street light.
  3. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    Wait a minute most of the aftermarket TCLs and other body shop company models that they buy I have two or three different sets on two or three different cars here and all of them have the adjustments they move the tray inside the housing up and down I do know when I put LED bulbs in I have to make like 9/2 turns down until the cutoff shows and then you line that up on your proper height on your garage door or whatever it is you're doing. So I'm not sure what's happening I mean I guess you could get a crap set but that's interesting I'm talking the ones I've been buying are in the same price range maybe even some a little less had no adjustment trouble so far and I'm running LED h4s and all of them except for the generation 3 h8 and H11.
  4. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    DEPO replacements have been okay for a few other cars; haven't tried their Prius-fit parts yet. Closer to $120 each side for most models.
  5. Old fat fireman
    Connecticut
  6. Old fat fireman
    Connecticut
    Installed sealight s1 h4 bulbs, pattern sucks
  7. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    Wait, so you haven't seen the pattern with real bulbs in it yet?
    Lots of aftermarket LEDs give garbage patterns when they're installed in (unmodified) buckets meant for halogens.
  8. Old fat fireman
    Connecticut
    Update, bought new headlight assemblies from depo, minimum adjustment, perfect, learn from my mistakes, don't buy cheap 20230903_201712.jpg
