New here, few issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PriusPrime, Jul 18, 2016.
  1. PriusPrime
    PriusPrime Junior Member
    Cave Creek
    I have a 2006 Prius with 210k on it. And here are a few issues I have going on with it.
    • Intermittent ABS, BRAKE, VSC - Comes on. Turn car on and off, its gone.
    • Intermittent Right Side HID - On/off. Sometimes stays on all day, other times turns off.
    Here is the information I am getting from battery voltage. Regular voltage is 12.4+, under load its been at 11.5v
    also here are some codes I got for the ABS, VSC, Brake lights:
    • C0200 RIGHT WHEEL SPEED SENSOR
    • C0205 LEFT WHEEL SPEED SENSOR
    • C1249 STOP LIGHT SWITCH OPEN CIRCUIT
    I hope that was thorough enough. I hear and read a mixture of things, a 12v battery could be causing ALL of this. Some say odds of both front sensors going out is minimal, but, who knows. I will try cleaning them tomorrow and see if that helps. Battery replacement time? Thanks a bunch!
    #1 PriusPrime, Jul 18, 2016
    48,996
    welcome! so, how is your 12v health?
  3. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
  4. PriusPrime
    Cave Creek
    Regular voltage is 12.4 +/-, under load its been at 11.5v
  5. bisco
    48,996
    12.4 isn't bad. is that a stone cold battery with everything off?
  6. PriusPrime
    Cave Creek
    Yes. But under load, we are going under 12v, hitting 11.8 at first, now, 11.5v
  7. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    ...this member grabbed the PriusPrime User Name!
  8. bisco
    48,996
    isn't that natural for a battery under load? depends on the load i suppose. how old is it?
  9. PriusPrime
    Cave Creek
    I replaced the 12v with a Bosch AGM battery from Pep Boys $150. Not bad for AGM. No lights since.
  10. wjtracy
    11,314
    3,588
    Northern VA (NoVA)
    Good! I think you are saying no warning lights.
    If the warning lights come back, Fotomoto at Post#3 re: brake actuator is a possible explanation.
