New Here. Looking to purchase first Prius
Discussion in 'Gen 2 Prius Main Forum' started by BDunn, Mar 4, 2019.
  1. BDunn
    BDunn New Member
    North America
    Hi there. I have never owned a Prius before and I'm looking at a 2005 Prius. It has 183,000km on it and it's being sold with a valid Safety, which is a good start.
    Everything looks good on the vehicle from what I can see on the pictures. No rust, no body damage or anything like that. Is there anything I should ask specifically or look for in particular while looking at this vehicle?
    Thank you in advance.
    EDIT: I've been reading a lot about these vehicles burning oil. Is this a common issue?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat !!
    Check the service and recall history by running the VIN at http://www.toyota.com/owners (it may not exist for Canadian VINs), and again at Carfax if something looks funny. You should also be able to go into a dealership and pull the service records.
    Burning oil is fairly common with a higher mileage gen2, check the oil often or risk losing the engine. Oil also plugs up the $1300 catalytic.
    Do you have a plan (or a secondary vehicle) if something expensive breaks down on this new to you vehicle ?
    How much are they asking for it ?
    Raytheeagle likes this.
    52,695
    a 2005 will likely need a $3,000. battery soon, possible a combo meter and brake actuator
