New HIV Battery is not charging
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, May 18, 2020.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Dears
    I need help here..
    I have installed a new hybrid battery since mar 2019
    But i noticed today that the battery is not charging while driving.. i need to konw what to check or what to reset if possible
    Thanks in advance
    52,824
    is it brand new toyota?
    has it worked up until now?
    are there any trouble lights?
    are there any other symptoms?
  3. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Hi..
    No it's prius 2010 but the battery is brand new from toyota and there are no warning lights !!
  4. Tariq87
    Tariq87 Member
    87
    28
    jordan
    The semptoms is just the gas engine is running...without charging the battery
  5. bisco
    52,824
    you obviously have enough battery to start the engine. that tells me you have a bad ecu or wiring issue.
    but no trouble lights is troubling
  6. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Lem ask you a question..
    Dose the inverter "the pictuer is attached" effected by high weather temperature? Even the coolent is full
  7. bisco
    52,824
    not that i recall reading about
