New hubs, rotors and pads
Discussion in 'Prius v Accessories and Modifications' started by HawaiivGuy, Mar 14, 2023.
  1. HawaiivGuy
    HawaiivGuy On the Way
    27
    Hawaii
    2013 Prius v wagon
    The car developed a “shimmy” when braking downhill. Figured might as well change all the wheel hubs. Then since I did the hubs, might be time (130,000 miles) to change the brakes. 2D1A6CB4-23D3-4C95-A975-264F1316F6E9.jpeg
    jzchen likes this.
  2. Tombukt2
    Tombukt2 Senior Member
    13,398
    2,411
    Durham NC
    Yes might as well you're on knees anyway.
  3. Mendel Leisk
    41,892
    Hubs means wheel bearings?
  4. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    It's 10 years old, could just be an issue with one of the pads sticking or even a caliper....also the caliper pins should be checked to make sure they still slide about freely with the pads...but replacing them all, at this point, probably isn't a bad idea.
    When you have the tires raise up, grab them at 12/6 and 9/3 and give a good wiggle...if you have excess play a wheel bearing or support rod could be needing replacement.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    What year is the v? At 130k you should take a look at the EGR cooler, EGR valve, and the intake manifold EGR passages for sure, if you haven't already done it.
    Our 2011 hatchback's EGR cooler at 124K was about 80 percent obstructed with oily carbon gunk.
  6. Air_Boss
    Air_Boss Senior Member
    4,222
    1,188
    New Yawk
    Could also be a separated belt in a tire…
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    Yep, had a big bulge in the tire on our Corolla in the rear passenger position. Was causing vibration and a thumping sound. Took a while to pinpoint what the cause was.
    This is what the tire looked like when it came off the car. It was definitely going to fail catastrophically at some point. 20200618_114334.jpeg 20200618_114357.jpeg
    Air_Boss likes this.
