New HV battery and doesn't run
Discussion in 'Gen 2 Prius Technical Discussion' started by Cybersurgeon, Jan 25, 2020.
  1. Cybersurgeon
    Cybersurgeon Junior Member
    45
    Reno,NV
    Four Touring
    It’s not getting any codes at all
  2. Cybersurgeon
    45
    Reno,NV
    Four Touring
    BAFX OBDII Wi-fi. It’s reading again but so far no codes. Nothing.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Doubtful that hardware device is compatible with techstream (dealer diagnostic software), which app are you using if not techstream?
  4. Cybersurgeon
    45
    Reno,NV
    Four Touring
    The one the company says to use. Car Scanner. I got it from the App Store. Just like the instructions said too. I’m going to send the car too a shop. I give up
  5. George W
    George W Senior Member
    937
    520
    San Antonio
    What company? Some readers don't speak Hybrid. At the budget end, this one always works for me.
  6. bisco
    52,790
  7. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Never heard of that app before, mustn't be very useful with a hybrid.
    Since you mentioned "app store" we will assume that you're using an iPhone, before shipping it off to the shop, try a copy of Dr Prius at : ‎Dr. Prius / Dr. Hybrid on the App Store
  8. Cybersurgeon
    45
    Reno,NV
    Four Touring
    This is the code reader. So, it says it works on Prius’s.. The Guy from Prius batteries says they should all work.
    Just feel like a cat chasing it’s tail.
  9. Cybersurgeon
    45
    Reno,NV
    Four Touring
    That’s not compatible with iOS (apple)
  10. George W
    937
    520
    San Antonio
    SFO recommendation is your best bet. I didn't realize you were IOS.
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    The code reader is fine, assuming the iPhone is compatible. The "recommended app" may be the issue, so give Dr Prius a shot.
    Maybe another iOS user can recommend another app that is known to work?
  12. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    This is killin me...........
    I want to help but just don't know where to begin..Guess I need to find the first thread.....
    SFO likes this.
  13. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Well I am not sure. After answering many emails back and forth while out of town over the weekend at all hours, and him admittedly not reading the instructions until most of the way through, I am not sure what more I can do to help diagnose.I am glad he made a thread to crowdsource suggestions.
    If the car will not READY, there is a basic fault. Most likely the safety disconnect. As I mentioned many times, and everyone here has mentioned too, it is tricky to get in correctly. It can look and feel like it is seated properly, and it isn't. That's the first step.
    Then the next most obvious "whoops" is just forgetting to reconnect all the little wiring harnesses inside the battery for the ECUs and then the 12v battery. Our instructions do specify to disconnect the 12v battery, so you will need to press the power button multiple times for it to come up.
    Since none of that is happening and just a whir or buzzing sound, it seems like the relays in the back aren't kicking on. Could be a low 12v battery, missing a 12v connector (there are 2 back there remember), missing a basic ECU connection so the car doesn't start up because it knows there's a problem.
    Looking at the images of the installation that were sent over, everything in the frame of the picture looks good enough.
    The fact that there are no codes stored at all, yet it won't READY, says to me it's something basic. If there was a HV Isolation fault for example and that was the reason the relays wouldn't click over, that 100% stores a code in the HV ECU.
  14. George W
    937
    520
    San Antonio
    Are the harness's tested for continuity before shipping?
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    They are tested at the factory. We don't test them again before shipping. It has happened a few times where during torquing of the bolt into the module with the bus bar and wiring harness, people use a power tool and when the sense wire isn't held stationary it then spins around the bolt, sometimes snapping. One reason we do not recommend power tools for that, at least not the actually tightening process. But people gonna do, what people gonna do. :/
    But if that were the case, you could disconnect the sense wire from a block and the car would start. You would get an error about a block being too low in voltage (code stored in HV ECU), but the car would READY, the battery would charge, and the car would even drive.
  16. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I'd recommend against sending the car to a shop unless you're OK with the additional expense. If you can find an independent hybrid mechanic, maybe that would be best. But if you take it to a dealer, they aren't going to really have any better clue than you, and will charge you for it. We don't accept returns on installed equipment for obvious reasons.
  17. George W
    937
    520
    San Antonio
    I hope it isn't a harness issue. The replacement was a little tight inserted at the bottom of the tray. I think the OEM is a touch longer. 177170_received_575699523199957.jpeg
  18. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Your post #21 in this thread shows a dashful of lights plus the Hybrid System Problem icon on the MFD. So, there must be codes.
  19. Cybersurgeon
    45
    Reno,NV
    Four Touring
    I took it to a shop and they got codes. P3004 code. I forgot to put on the main negative disconnect cable. They are working on it, as I give up. I'm a "rookie" who had no business playing with a Prius that had so many issues. I'll get it running and sell it. I just bought an Abarth 500c for my daily driver.
