New Inverter Coolant Pump, No Joy
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Duncwarw, May 14, 2024.
  1. ChapmanF
    18,997
    I don't have the number offhand, but in case nobody else comes around with it and you need to look it up yourself, this post may make it less of a challenge.
    Of course you'd be clicking in Engine Compartment, not Body (which was just for that example).
    Duncwarw likes this.
  2. Duncwarw
    Duncwarw Junior Member
    50
    Capital Region, NY
    The positive wire broke off at the plug when I touched it.
    I jumpered the pump and bled the system. Now to find that plug and go back to the missing ECU problem...
  3. Duncwarw
    50
    Capital Region, NY
    In an effort to "give back" in the hope that I can help someone else, the Toyota part number for the inverter pump power plug is 90980-11162.
    The stealership sells the plug and wires as three distinct parts ( the plug, the positive wire and negative wire), each wire costs about 10 bucks resulting in about $40 to you.
    The wires are a few inches long with connectors already attached. You just snap them into the plug and connect the other ends to your wiring harness.
    Fwiw, I also bought the parts in one piece from Amazon for , I think $14. Already assembled but lacking the "filling". I'd use silicone sealant or the like. Obviously, I didn't use the Amazon plug (yet) so I can't comment on its quality.
    mr_guy_mann likes this.
