New inverter pump installed, not working, what could be wrong?
Discussion in 'Generation 1 Prius Discussion' started by Jtaylor1111, Jan 6, 2024.
  1. Jtaylor1111
    Jtaylor1111 New Member
    Vermont
    2003 Prius
    2003 Prius. I posted about this earlier but we now have a new issue. Our car kept dying, though we were able to still drive normally most of the time, but I investigated online and checked the inverter pump, and realized that there was no movement in the reservoir, so I assumed the pump failed and we had a local (not a a Prius) mechanic change it, and the car seemed fine after he changed it when we went to pick it up and drove it home (about five miles). The next day, we turned it on and are getting red triangle and the car with the exclamation mark (not happening before we got the pump changed), and the car engine turns off after about one minute. We ran our OB2 scanner tool and got the code p3191 that apparently just means that the engine won't start. When we looked in the reservoir at that point, there was very little movement, and I asked the mechanic and he didn't know to look in there, so didn't check to see if it was working. Now there is NO movement at all in there, and I am wondering if there a common mistake that my mechanic (not a Prius mechanic) might have made changing the inverter pump so that it barely worked, and now has stopped working? It was a new OEM pump.
  2. Jtaylor1111
    Vermont
    2003 Prius
    Update - the pump apparently is working but it is barely moving the coolant but is vibrating and when we attached the bleeder hose to the right bleeder screw, it did send coolant through (and there was air in there at first, and we did need to add fluid to replenish it (maybe a half a cup?). I am thinking that because it is Vermont in the winter, it is just really cold so not moving like it would in the summer (about 20 F out there now)? However, car still will not stay on (about 45 seconds) and so next we were going to look at cleaning the throttle body plate and the MAF sensor since we have had to take the 12v battery out a lot (because we aren't able to drive the car) and my understanding is that it might cause the car to be more sensitive to throttle body plate build up, etc. Spark plug was changed less than a year ago, so not think that it is that and the oil level is fine and the right one to use, etc. We also tried to keep the car going by pressing on the brake and reverse at the same time, but not work, and we are really worried about running the hybrid battery down by trying to start it over and over... Any other ideas about how to trouble shoot p3191?
  3. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    This might sound unrelated to you, but there is a simple test you can do to check to see if your 12v battery is putting out adequate power to boot up the system to start properly.
    First, check that all connections to the 12v battery are free of corrosion and tight. Including the ground cable connection at the chassis.
    Put the car ro the "acc" position where the dash lights are on but the car is not started. Then measure the voltage of the 12v battery. You can measure it at the battery or at the jumper link in the fuse box under the hood.
    If the voltage is 12.1v or less, your battery is insufficient for booting up the system properly.
    This can cause numerous issues, such as inaccurate codes and trouble lights being triggered, and ECU dependent components and functions not working properly.
    Seriously, do this. It may save you from wild goose chasing problems.
  4. ChapmanF
    18,990
    I've yet to see anything to convince me of that claim. In the Toyota repair manuals, there will often be a note advising you to make sure it's at least 11 or to charge or replace before proceeding, and that seems to be conservative too (as you would expect them to be); any problems I've ever experienced with "booting up the system properly" have kicked in well below that.
    Some of the ECUs in the cars do have trouble codes they are programmed to set when the voltage goes below a threshold, generally 9.5. So if you try to power up and that happens, you will end up with those codes (even though the system may otherwise boot up just fine). Those won't be fake or spurious codes or anything; if you look them up in the manual, they're the exact ones that mean "hey, did you know the voltage went below 9.5 here?" and the ECUs that set them were properly doing just what they're programmed to do.
    Brian1954 likes this.
  5. Jtaylor1111
    Vermont
    2003 Prius
    Thank you for your recommendation but it is a new (in the spring) 12V battery and we always test it before we put it back in the car (keep it inside during the winter in VT when the car isn't being driven) and we also have been extra charging it (shows over 13 volts) before we took it out yesterday, so this is definitely not our problem. Also, while we have gotten a lot of different strange codes when our 12v battery has failed in the past, this one is pretty specific I guess to what makes the car engine start. My question is whether there is anything else to check other than than a dirty throttle body plate or dirty MAF sensor? We have been getting O2 sensor codes check engine light for a long time, but not wanted to change cat converter - could this be related to the issue? Thank you
  6. Trombone
    Trombone Active Member
    384
    129
    Allentown, Pennsylvania
    2002 Prius
    What Chap said. My '02 will boot to "Ready" with less than 12V showing on the ScanGaugeII.
  7. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    It's very unlikely that O2 sensor problems would cause this. And if it's the downstream (sensor 2), then it's absolutely not that.
    What kind of code reader are you using? Many generic ones are pretty lousy about pulling codes outside the standard OBD 2 ones. It seems yours is at least picking up the P3191, but I'd be surprised if there aren't more codes stored in there.
    For a hoot, unplug your MAF sensor, start it up, and see what happens.
  8. Jtaylor1111
    Vermont
    2003 Prius
    So you can just unplug it? I bought some MAF sensor cleaner today, and was going to try to clean it and the throttle body plate tomorrow (not very mechanical, so having someone help me with a bit more engine experience), but if I just unplug it, what does that mean?
    Also we are using a VGate Scan V8600 OBDll/EOBD
    BruceBerq1 likes this.
  9. ChapmanF
    18,990
    Quick way to find out if the code scanner you're using will even show you the trouble code you know you have because the sensor is unplugged.
    Jtaylor1111 likes this.
  10. ronlewis
    ronlewis Active Member
    1,059
    205
    texas
    2001 Prius
    If you still have your OEM cat, you might check the HCAC actuator, especially in Vermont. Maybe it's rusted shut, so it won't open up after your converter warms up. That would trigger the ox sensor codes, I'd think, and mess with the ECU's fuel mixture. That usually throws codes, but I've not heard of your scanner, maybe it's missing them. Also, you don't have to replace the cat to change out the ox sensor.
    BruceBerq1 and Jtaylor1111 like this.
  11. ronlewis
    1,059
    205
    texas
    2001 Prius
    On your pump, you should be able to hear it running. It's right behind the driver's headlight, and it makes the kinda noise you'd think a small electric pump would make. IIRC, it should be running with just the key turned to ACC, it doesn't have to be in Ready mode, so it's easy to hear. If your tech hasn't thrown that old one away, get it back; it's probably still good and you'll have a spare. Or sell it on Ebay pretty fast, one of the easiest Prius parts to sell. Test it with just a hot wire and ground to the connector to make the pump run.
    If you can't hear the one in your car, then you need to check the power starting at the pump connector and going back through the fuse box to the ECU, see where you're losing power.
  12. BruceBerq1
    BruceBerq1 New Member
    Tamworth, NH USA
    2003 Prius
    Sorry you can't see the obvious general and computer science in my statement. And Yes as you say the system will start down to even below 10 volts.
    So will my 19 volt laptop start up at less than 9 volts too. But not without issues and certain functions being compromised for either the Prius system or my laptop.
    In fact, low voltages have more of a tendency to cause damage, even over reasonably too high of voltage, though both are insufficient for proper operation.
    I have had far too much experience with this voltage issue in computer, ECM, ECU vehicles, where voltages below 12v absolutely can create ghosts and glitches in the diagnostics and even in certain functions.
    Oh sure, but they run...
    And certain components recover okay once running with the battery receiving 13.5+ volts.
    But not all, especially in certain components such as parts of the ECU, ECM, and other computers.
    Deep Cycle type batteries such as recommended in the Prius are very voltage resilient, that is why toyota uses then in this hybrid system where they are relatively passively charge from an invertor and not an alternator, and can take considerable discharge at times.
    That is why a low battery should be charged then tested before determined bad.
    And this is why, mostly otherwise for marketing reasons, Toyota wont list a battery charge as insufficient till below 11 volts. And 9.6 volts is indicative of a low charge under heavy load.
    No. You are not wromg.
    Neither am I.
    I have demonstrated this and applied my diagnosis of this so many time and very successfully not just for myself, but for customers (before I retired) and for many people that i have cuurently assisted and advised who have come back to me with successful results and not had to do the coded repair that was supposedly needed per the almighty (sic "Flawless") code reader.
  13. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    I can't say for sure on this specific engine - but on many cars that use MAFs, the car will run with the MAF unplugged. So if it's not running with the MAF, but runs with it unplugged, then the MAF is bad. I don't know the specifics, but I'd imagine that without MAF info the computer just uses substitute values based on throttle position. That's a guess.
  14. ronlewis
    1,059
    205
    texas
    2001 Prius
    Not to nitpick, but there could also be wiring issues interrupting the signal from the sensor.
    Josey likes this.
  15. Josey
    Josey Active Member
    305
    117
    Virginia
    2003 Prius
    LOL. Not a not a nitpick @ronlewis . You are indeed correct! Always inspect/check the wiring before condemning a part.
  16. ronlewis
    1,059
    205
    texas
    2001 Prius
    Just a general info add-on, and I'm not sure it completely applies to these cars, but it does on my Ford diesels...
    When I see multiple codes appear, some of which don't seem to logically relate to others, the first thing to check on my trucks is "reference voltage," or as I think of it, "network voltage." All the truck's sensors are connected like a LAN such that any short/grounding of the LAN's reference voltage can distort/cause/omit sensor voltages connected to the LAN. There's a Vref datapoint on TorquePro for my trucks that should always be +/- 5v. Multiple unrelated codes is a basic red flag for Vref issues, which isn't usually the problem, just the first thing to check, like fuel and charged battery. But, if it is the issue, it can be a PITA to find the short anywhere in the LAN wiring.
    Also, TorquePro and my Forscan (Ford) tool both list codes in the chronological order in which they were set, which is usually a good way to try to fix them, but also, you might logically assume that some later ones were actually caused by earlier ones and will disappear when the first is fixed. If you start at the bottom, you could waste time/money.
  17. ChapmanF
    18,990
    "Multiple unrelated codes" in PriusChat posts often turn out to be, instead, instances of "multiple codes I think are unrelated." :)
    The Prius is a network of a bunch of ECUs, and sometimes people are surprised that the ECUs actively gossip with each other. Some ECUs have specific codes they will set just because some other ECU set some codes.
    So, for example, it's pretty common to have the engine control module set some code (about something really happening with the engine), and the HV control ECU set a code of its own like P0A0F (hey, I asked for engine and didn't get it), and the braking and stability control lights come on with C1259 and C1310 (hey, we noticed the HV control ECU set a code).
    Then the owner says "this is nuts! I got engine and hybrid and brake and stability lights all at the same time!' but if you just breathe and look up what the codes mean, it all tells one coherent picture.
    ronlewis likes this.
  18. ronlewis
    1,059
    205
    texas
    2001 Prius
    My trucks have known issues with the harness chafing at different stress points around the truck to cause a short. We're lucky that we don't see more wiring issues on these cars, which are the same age. But yeah, not usually the cause of multi-codes, however, it's the basic first step and so easy to do with TP/Forscan.
    I mention it because I don't get many datapoints for these cars using TP - RPM, temps, system voltage, is about it. I assume that you get everything with Techstream and maybe some high-end tools for Snap-On, et al. So, I don't even know if there's such thing as Vref on these cars. I'm flying blind most of the time with only whatever codes TP captures.
  19. ChapmanF
    18,990
    These cars use multiple network technologies, especially Gen 1, pre-CAN and quite a hodge-podge: BEAN, AVC-LAN, and serial links. It would be too much to assume there's a single concept or value like Vref that applies to them all. The manual does have some details of those individual technologies. It doesn't tell you a lot about their physical layer specs, but generally enough to get through troubleshooting.
    It's worth addressing this straw man wherever it comes up. There is no "coded repair" "supposedly needed" by a diagnostic trouble code; not that there aren't people too often treating the codes that way, but that's their mistake. The only thing a DTC tells you is that the detection conditions listed in the repair manual for that DTC happened. It is always up to a human to find out why those conditions happened, and what to do about it. People who proceed accordingly when interpreting a DTC get successful results. People who misuse DTCs aren't really the best population to measure some other methodology against.
  20. ronlewis
    1,059
    205
    texas
    2001 Prius
    Yep, doesn't look like it applies here. Had to look up the DTC - P0641. Nowhere to be found in this forum or the service manual. Google shows it in GM and Ford products for sure, along with detailed articles on "vehicle reference voltage," calling it "complex." That leaves me out, lol.
