New issues after engine swap
Discussion in 'Gen 2 Prius Technical Discussion' started by Sharnold, Jan 22, 2019.
  1. Sharnold
    Sharnold Active Member
    409
    126
    Alabama
    So per my previous posts about the hybrid battery as luck would have it the car cranked and charged the hybrid battery. Now as luck would have it I'm getting
    P0117
    P0116
    Any takers I'm open for suggestions
    Also is not circulating heat in the car
    Faulty water pump
    Temp sensor as stated by code and if so location?
  2. Sharnold
    409
    126
    Alabama
    Engine head temp after a 30min drive outside temp @ 35°F . Also the car goes from driving great to being very slow and sluggish
  3. Sharnold
    409
    126
    Alabama
    I'm leaning on thermostat as the upper and lower hose are pressurized and hot
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    If you’re reading 216, that’s too hot:cool:.
    I’d say the thermostat is toast as temps should be around 190-195;).
    Good luck and keep us posted (y).
  5. Sharnold
    409
    126
    Alabama
    Problem Is I changed the engine with one that was pulled from a junkyard it's been years since it ran. Plus I had lost of coolant in the CVT but I know it's full as the reservoir and inverter is circulating with no air.
    My concern is since the upper and lower hoses are hot and pressurized the cars thermostat is locked shut and not opening.
    I replaced the inverter pump its circulating water but after that drive the water on that side was ice cold.
    Could this be air in the system issue? I doubt it considering houses where stuff and tight.
    So basically I'm afraid I'll be pulling the thermostat first considering I'm getting no cabin heat at all.
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Can you put the thermostat from the old engine in?
    Plus you didn’t post how you fixed your problem in the other post. Please do that as others might find it useful.
  7. Sharnold
    409
    126
    Alabama
    Problem with the temp air bubble in the engine and upper radiator hose I jacked up the passenger side of the car and filled the radiator and engine while squeezing upper and lower lines removed all the air...... presto I have heat and no codes......as far as the HV issue let's just say thank you Power Wheels chargers from Walmart....... please hold back your laughter........
    Skibob, Raytheeagle and Mendel Leisk like this.
  8. Sharnold
    409
    126
    Alabama
    Car did great circulation was good heat was on then I just pulled a P0116 the P0117 never came up again this car is confusing me I've never had this much trouble from a single prius
    Engine head temp was 165°F at time of code
  9. Sharnold
    409
    126
    Alabama
    Problems are all solved bled air out one more time and just drove 15miles no codes....... I appreciate all your help
    Raytheeagle and Skibob like this.
