New key fob
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Jan 19, 2022.
  1. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    My 2102 Plug in only has one smart key. What’s the cheapest way to add a spare, in case the one key is lost? I do t care about the mechanical part of the key, just the fob part.
  2. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    You are free to purchase a used key fob off ebay for a significant savings, but it must have been cleared by the seller; they call this a virgin key fob. Most professional resellers will give you a new uncut blade key too, you will have to bring that to a locksmith to get cut to match your current key, or dont, I never do. Otherwise, your other option is you are on the hook for a new OEM key fob for a lot more, and still have to get the key cut and programmed $$. Your choice, your money.
    You get this key fob, and you can find a locksmith in your area with the proper handheld equipment to program it to the car, or purchase Techstream software off the internet (super useful anyways) with an OBD2 cable and program it yourself. I have done this several times to all my Pri, and coincidentally (are you reading my mind?!) just did 1 last night for my newest Prius. Takes all of 5 minutes.
