New Liquid Battery
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Bill Merchant, Mar 8, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Your water heater has almost zero insulation. Make that water heater the size of municipal water tank and surround it with forty feet of high R value insulation. The heat losses would be minimal compared to the losses of other electrical storage techniques, such as pumped storage.
    Tom
  2. darelldd
    6,059
    389
    Northern CA
    I have to ask: What is the difference between cars and EVs? Silly me, I thought they were one and the same. At least we sure drive our EV as a car. I hope we aren't doing it wrong! :)
  3. qbee42
    18,058
    3,076
    Northern Michigan
    Cars are a mode of personal transportation. EVs are an imaginary form of transportation. :p
    Tom
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i can believe that.... i see people every day staring at me with disbelief
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Yes, of course you can. I'm talking about large industrial processes where certain components are specifically engineered to provide such a steady-state operation, or for certain batch operations
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Eg: the surface area and loss of a domestic hot water tank vs that huge industrial tank ...
  7. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    Cars are automobiles, which is driven by an engine.
    EVs are driven by motors and assuming non-polluting, kind of like a faster golf cart. :)
  8. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I would like one of those Tesla golf carts.
  9. qbee42
    18,058
    3,076
    Northern Michigan
    I thought EVs were powered by bunny hugs and butterfly kisses. At least that's what darreldd told me.
    Tom
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Smirk, snicker
  11. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    But so can gasoline if it's not protected!
  12. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    It's interesting to see what you read into this, and not read (or understand) what's in the article. All the electromotive components are liquid: the metallic cathode and anode are molten metal, the electrolyte is a molten salt. Charging "precipitates" the molten metal out of the salt, discharging "dissolves" the metal in the electrolyte, though all components are liquid. Sloshing? I don't think so.
    Yes, this is a high-temperature process, but so are the explosions of hydrocarbon vapor in the ICE cylinders. I didn't see any energy-density figures, but this could be a small device if the density was high enough.
    I still think some sort of ultra-capacitor is the real solution, keeping electricity electrical all the time, but the capability of this battery to absorb and discharge high current rapidly is a real breakthrough.
  13. darelldd
    6,059
    389
    Northern CA
    I usually call it "rainbows and the laughter of children." Not like you to get that wrong seeing as how you hang on every one of my words, Tom.
    It will be a breakthrough if it is commercialized, at least. Just like the EEstore capacitors will be "real breakthroughs" if they ever materialize. I usually reserve "breakthrough" for items that exist out in the wild.
  14. Bill Merchant
    4,096
    85
    I didn't know that you were the "breakthrough" arbiter. How unlike you not to tell the world. Thanks for the update.
    Can you show me another battery that is comparable in design or current handling capacity? The Technology Review article says, "The battery is unlike any other." and "Solid materials limit the conductivity of batteries and therefore the amount of current that can flow through them."
    I think the concept is a breakthrough. The concept has been demonstrated in pilot form, so it's not just theoretical. I hope it can be commercialized for grid storage, that would be a technological triumph.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Well, unfortunately, there are "breatkthrough" ideas out there that have been shelved due to exotically high unit cost, lack of appropriate mass-produced hardware, etc.
    Consider that the idea behind a Prius really isn't "new."A vehicle like the Prius could have been built two decades ago. Only catch is that the hardware would have needed several chest-freezer size cabinets to fit in
    Before IGBT's, things like variable speed drives (Variable frequency drives) were huge things. A VFD for a three phase 20 hp industrial motor easily required a box the size of an upright freezer
    Of course, Tom and I also remember the dawn of "electronic" process control. Eg: a TDC 2000 with a "Hiway" data network, running Enhanced Operator Stations.
    Eight years later, when TDC 3000 came on the scene, the Hiway Gateway relegated the former "high speed" network to a low speed interface for RTD's and ORP's
  16. qbee42
    18,058
    3,076
    Northern Michigan
    LOL. :) Yes, I usually follow Darell with a sappy look on my face and my pencil and notebook at the ready <sigh>.
    Tom
  17. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    This "liquid" battery requires molten metal - so it's a lossless design made for storing surplus energy to be used in times of need.
    Think of it as a giant UPS for a power plant.
    No way this tech is for cars or at home. Whoever designed the Picture forgot to include the Scale in Meters. This must be huge to be efficient.
  18. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    jus read article about charging breakthru at MIT where Li batts can be recharged safely within seconds...
    **prelim info only**
    as always, a "few" drawbacks...for one thing, it would need a special charging system, because during testing runs, even with something as small as a cellphone battery, it drew 350 amps... so house charging circuits would be out... they are now investigating solutions that slows down the charging process a bit with less current draw... but its a start.
    **edit**
    http://news.cnet.com/8301-17912_3-10194721-72.html?part=rss
  19. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Yes, I remember being told that computers will always require entire buildings to hold them (and now I use one as a door stop).
    Obviously the first generation may take 5 to 10+ years, but if money can be made by putting them in vehicles, then it's going to happen.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Like the IBM Semi Automatic Ground Environment, or AN/FSQ-7, used for early radar defense:
    AN/FSQ-7 "Whirlwind II" Intercept Computer
    MITRE Corp was instrumental in development of SAGE
    MITRE - About Us - MITRE History - Photo Archives - Semi-Automatic Ground Environment (SAGE)
    Since SAGE was conceived in the mid 1950's, not only did it run on a few vacuum tubes - around 100,000 of them - but the consoles also had built-in ashtrays and cigarette lighters
    IBM Archives: SAGE console
    Ah, the good ole days
