New member and a starting question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fredpowled, Mar 10, 2016.
  1. fredpowled
    fredpowled New Member
    Tucson
    The battery in my turn-on-the-ignition-remotely in my Prius 2006 fob finally wore out, so I replaced it. Now I have to insert the fob in the slot in the dashboard in order to start. No big deal, and entirely understandable given the age of the battery, but now that I have the new battery installed the fob insists on being inserted in the dash before I can start the car, where before I needed only to be within a few feet of the car. A Prius dealer employee told me it was because I had the battery in upside down. Not true. Any help, please? --Fred Powledge
    49,732
    try checking your 12 volt battery. maybe a coincidence?
    what about your other fob?
    also, check the voltage of the new fob battery.
    WilDavis likes this.
  3. fredpowled
    Tucson
    I should have mentioned that my wife's fob works remotely just fine. FP
    49,732
    is this 3 door sks? her fob works the remote starter, and you don't have to plug it into the dash?
    sorry, i think i am confused. i thought you mentor remote engine starter.
  5. wjtracy
    wjtracy Senior Member
    11,329
    3,593
    Northern VA (NoVA)
    I was not aware of a remote engine starter...doesn't everyone have to Press the Power button?
    CR2032 battery needs to be + side up when you put it in.
    PS- Welcome!
    #5 wjtracy, Mar 10, 2016
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,235
    Madison, Wisconsin
    Is the "KEY" button by the driver's knee pressed in?
    If it is, press it again so it is out.
  7. wjtracy
    11,329
    3,593
    Northern VA (NoVA)
    Right the smart key system has an on/off button under the steering column
