New need advice plz.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mal14, Sep 27, 2017.
  1. Mal14
    Mal14 New Member
    I have 2014 prius with 80k miles and except for oil change and cabin air filter and air filter. I haven't done any other service on it. Now my MPG has dropped to 4.2 and taking off is not as quick as used to be. Please I need some maintenance advice. Thanks all of you.
  2. JC91006
    16,872
    8,619
    Mpg is 4.2 miles? So you're at empty after 50 miles?
    Grit likes this.
    52,536
    welcome! how many miles per year are you putting on her? is that 4.2 liters per 100 miles?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Cheapest solution, pump up your tires to 40 psi in front/38 psi in rear.
    It is early, but check your 12 volt battery.
    Wheel alignment would need to be horrible, does it track well?
    What does the dealer say?
  5. Mal14
    Mal14 New Member
    It used to give me 50mpg or higher but the past couple of month the mpg has dropped.i use shell gas only and mobile 1 0w20 oil
  6. Mal14
    Mal14 New Member
    I have new tires on it and doesn't have a track yet.12 v battery is good. Haven't took to the dealer yet. My warranty is done n not trying to deal with dealer.
  7. Mal14
    Mal14 New Member
    I used to drive it a lot and I bought this car new in mid 2014 and now has 80k miles on it.the mpg used to be 50.mpg or above and now it's 42.00 or lower.
    mjoo likes this.
  8. JC91006
    16,872
    8,619
    It's the new tires
  9. Mal14
    Mal14 New Member
    i drove the car in those tires 20k already but the mpg dropped like 5k ago.so do u think it's possible it can be tires?
  10. JC91006
    16,872
    8,619
    20k miles is not new tires. Threw in a curve ball eh?
    I'd check the tire pressure and the 12v battery.
    My car gets around 40mpg with 17 inch wheels, so I can't say yours is bad
  11. Mal14
    Mal14 New Member
    Thanks JC and I will check my battery and the threads of tires r pretty new that's y I still call em new :) but are u happy with 40mpg?
  12. JC91006
    16,872
    8,619
    I probably can get 50mpg if I drive like Ms Daisy. But I like being a little aggressive sometimes. 40mpg is great, can't complain
    Mal14 likes this.
  13. bisco
    52,536
    dropping from 50 to 40 is 20% and there has to be a cause. if your style of driving, weather and commute is the same, you have to begin a process of elimination. tire pressures, 12v, throttle body, injectors, air and cabin filters, maf, intake manifold, egr, pct, etc.
  14. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    It's a long shot because the car is relatively new, but I've read that a dying traction battery can cause reduced mpg. At least it's still under warranty.
  15. mjoo
    mjoo Senior Member
    1,163
    1,333
    Michigan
    What would you say would be the average length of your trips now?
  16. interested
    interested New Member
    GB
