New OEM 12V shows 11.5V after two months?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ericspoor, Mar 7, 2019.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    Please see edited post #19.
  2. ericspoor
    ericspoor Member
    76
    37
    austin
  3. Mendel Leisk
    41,377
    A jump pack is for starting the car with a dead battery, emergency use only, to get you going. It's not a charger.
    Get something like a Clore CTEK 4.3 charger.
  4. JC91006
    16,766
    8,563
    Yes it does seem the battery is charging. But that doesn't explain why the battery is not reading 13.8v or higher when it's ready.
    You should fully charge the battery and go from there. That'll take a good overnight charge. Getting battery readings right after you drive is not an accurate reading
  5. ericspoor
    ericspoor Member
    76
    37
    austin
    whew thats a relief. I have the money to buy a new car but it wouldnt've felt good
    i live in an apartment complex- is there a recommended way to charge the battery that doesn't involve extension cables to a power outlet?
  6. JC91006
    16,766
    8,563
    You can take the battery out and charge it. Your hatch won't open without the working battery so you'll need jumper cables (connected to the charged battery) to connect to the front jump points to open the hatch. Or climb back there and release the hatch manually.
  7. ericspoor
    ericspoor Member
    76
    37
    austin
    Oh trust me ive gotten prettt good at the manual opening of the reat hatch haha. Ah of course, remove the battery and charge indoors. Okay, ill get on that
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Stop testing and jump starting from the battery in the hatch use the much safer jump point under the hood.
    It’s in the black plastic box under the hood the positive jump lug is in that box under a protective plastic red cover. Toyota put that jump point there to keep you out of the hatch. Jumping starting that 12 volt battery in the trunk is how so many Prius get damaged with reverse polarity jump starting.
    It does not matter what the voltage level reads at the battery posts it only matters what it reads at the front jump point where the main battery 12 volt cable is bolted too. By then it has gone through many connections and fuses and a long dc lead.
    Your battery has become sulphated and seems to not hold a charge well, buy a battery charger that has reconditioning mode that will help this issue.
    I bought the CTEK MUS 4.3 that Mendel recommends on amazon and it works very well. It has reconditioning mode which takes quite a while
    To accomplish.
  9. ericspoor
    ericspoor Member
    76
    37
    austin
    Good point, will do. Does reverse polarity jumping mean putting the red and black clamps on the wrong posts due to human error?
  10. Mendel Leisk
    41,377
    Yes.
    If the battery is Toyota, it likely has only embossed plus and minus indicators on top of case. I'd suggest to color them with something like a silver Sharpie pen.
    JC91006 likes this.
  11. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    Don’t worry what the voltage is when you just shut the car off. If it is charging it will have a surface charge. Check it after it has sat for some time, like when you get off work or in the morning before you go. Those are more accurate readings.
  12. Skibob
    2,912
    1,502
    Northern California
    Sulphated? The battery is only a couple of months old and it seem he uses it several times a week for work. It would be unusual for a battery to be sulfated under those conditions.
  13. ericspoor
    ericspoor Member
    76
    37
    austin
    i ordered this battery charger. not the cheapest but was the ctek brand mentioned and was prime one day shipping. will do the 8 step charging process and see if that does the trick
  14. Skibob
    2,912
    1,502
    Northern California
    Or you could have taken the battery out of the car and took it to where you bought it so they could test it. And since it’s only a couple of months old if it were bad they would have given you a new one for free. Just sayin. :whistle:
  15. ericspoor
    ericspoor Member
    76
    37
    austin
    thought about that, but since i technically didn't buy the battery from the dealership, the mobile mechanic did, i suspected that strategy might not have been fruitful
  16. Mendel Leisk
    41,377
    That's a 7 amp (max) charger. You may be ok, but there's a caution in second gen Owner's Manual, page 302:
    The CTEK 4.3 is 4.3 amps, and the CTEK 3300 is 3.3 amps. 4.3 is close enough to get away with it, 3.3 is safer.
    All that said, the 7 amp version may be ok, but overkill. More info on CTEK's:
    All Products– smartercharger.com
  17. ericspoor
    ericspoor Member
    76
    37
    austin
    Thanks for the check Mendel, i was able to cancel my order and get the 3300
  18. Skibob
    2,912
    1,502
    Northern California
    Did he not supply you with the receipt for the battery? Typically you need it to claim a warranty. Everyone knows this and your mobile mechanic should have.
  19. Mendel Leisk
    41,377
    Good stuff. I have one of each, a 3300 and a 4.3. I use the latter more now, but the 3300 has been simple and bullet-proof. A lot cheaper too.(y)
  20. padroo
    padroo Senior Member
    2,763
    2,252
    I have one of those chargers too but don't remember which model, they are high quality chargers.
    Once you get your battery charged overnight take it somewhere and have it tested. A battery has to be fully charged to get a good test.
    They are always willing to sell you a new battery. If it is bad you should contact the mobile mechanic and ask about warranty.
    After the battery is eliminated you will have to go after the charging system or a parasitic draw test. The Prius doesn't seem to have very many parasitic draw problems.
