New OEM hv battery post stud snapped
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jgcannon2, Jan 1, 2021.
  1. ChapmanF
    19,060
    If there's a rebuilder out there publishing a PDF that says 60 instead of 48, those guys might be throwing in a 60 in lb T handle instead, and we'd still have mishaps....
    donbright and Mendel Leisk like this.
  2. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    the prices they are selling and the marketing they are using...... smh.....
    2k1Toaster likes this.
  3. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Harbor Freight retail $19.95
    1/4 in. Drive Click Type Torque Wrench
  4. jgcannon2
    jgcannon2 New Member
    22
    Usa
  5. strawbrad
    953
    1,007
    Yeah, 60 inch pounds did not snap the battery studs. It's really hard to measure the difference the difference between 48 and 60 inch pounds. Here's a cheap 60 inch pound t handle with a 5/16" socket. A 5/16" and 8mm sockets are interchangeable. The difference is in thousandths of an inch. It is preset and freewheels once 60 inch pounds is met. It could be a good option for a DIY build. The wrench is designed to tighten hose clamps.
    https://www.lowes.com/pd/AMERICAN-VALVE-Torque-Wrench/1244081
    jgcannon2 and Mendel Leisk like this.
  6. ChapmanF
    19,060
    With a good T handle set for the specified torque of 48 in lb, you could probably call it right ten times out of ten.
    jgcannon2, strawbrad and Mendel Leisk like this.
  7. dolj
    dolj Senior Member
    8,657
    4,406
    Wellington, New Zealand
    By any chance is your new 1/4 inch in*lbs torque wrench dual calibrated with in*lbs on one side and in N*m (metric) on the other? I've been caught out with this once. Fortunately, I felt something was not right and checked it before I did anything disastrous.
  8. strawbrad
    953
    1,007
    The OP had a 48 in lb wrench and goofed up 2 out of four times. :(
  9. ChapmanF
    19,060
    The OP wrote:
  10. strawbrad
    953
    1,007
    You went way past 60 inch pounds to break the posts. Maybe it was a faulty wrench but there was operator error. With experience you can tell when you are way past the safe limits of a 5mm stud.
  11. alftoy
    1,132
    520
    HF user review for the the torque wrench
    No more stripping fasteners!
    I've ALWAYS stripped fasteners because I am very heavy handed. Per new electrical codes, every fastener on equipment must now be torqued to proper values. Since I needed torque wrenches, I figured I try Harbor Freight. Now these wrenches are heavy and the "lock" that keeps the handle from moving off of the value you set isn't the most user friendly. You have to really tighten the knurled set screw to keep the handle from twisting hence moving your setting. With that said, you can't get a less expensive torque wrench that has 4% +- accuracy. It also comes with a calibration certification. In my business, you MUST have a calibration certificate and the Plant I just worked at accepted it with no issues. However, it will cost you more to recertify this wrench than to just buy a new one so I'll be giving the expired ones away.
    jgcannon2 likes this.
  12. ChapmanF
    19,060
    The experience has to involve knowing the material of the M5 stud too. If you've got an M5 stud made from property class 5.6 steel, you're going for not quite 24 inch pounds. If it's property class 8.8 steel, you're going for not quite 55 inch pounds. (Quite a difference!)
    If it's a specialty stud made from unidentified electrical terminal material as part of a battery, there's probably no generic table to look up the safe torque in, so you're kind of reliant on the manufacturer to say what it is.
  13. jgcannon2
    22
    Usa
    Thanks; I've got one ordered.
  14. jgcannon2
    22
    Usa
    Actually, the first one,I felt the wrench "give" and thought it was up to value. It didn't fall off. #2 clearly snapped off, and I went to check #1 for finger tightness, then it fell off. So, #3 and #4 are just finger tight right now. I realized something was wrong and stopped. So I could still break them, too.
    Hopefully the t wrench you suggested will help me get it right; thank for the suggestion. Right, something didn't feel right, but I've only tightened lug nuts, so I have no idea what 48 or 60 in lbf feels like.
  15. jgcannon2
    22
    Usa
    Absolutely agree, operator error. It certainly didn't feel right, but I have no experience with this level.
  16. jgcannon2
    22
    Usa
    Yes, has both scales. Checked 3x to be sure I was on in lbf, so I messed up some other way.
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    hmmmmm....one thing you have to recognize is the HF torque wrenches, regardless of what they say, are NOT 'click' style wrenches. They do not make a firm click and release. What happens, is the handle makes a very slight pivot near the head. If you're torqueing and waiting for a click, that may be the problem. The handle will perform the 'pivot' and if not recognized, will easily allow the operator to continue cranking on it.
    jgcannon2, strawbrad and SFO like this.
  18. strawbrad
    953
    1,007
    The "click" of a Harbor Freight 1/4" torque wrench is very subtle. It's easy to miss and keep going past the set value. Also the 12" long handle is complete overkill for 48 inch pounds. The math shows that only 4 pounds of force is needed at the end of the wrench. A four inch long wrench would be more appropriate for tightening 5mm studs by hand.
    donbright and jgcannon2 like this.
  19. jgcannon2
    22
    Usa
    THANK YOU for that explanation! That's exactly my problem! I'm running around with two different wrenches trying them on the car lugs, and I can't get either one to click... This explains why! Yeah, no wonder I busted things!
  20. jgcannon2
    22
    Usa
    Gawd, no wonder! Thanks for the additional explanation. I can imagine that smaller force from your description. Very helpful.
