New old Prius
Discussion in 'Newbie Forum' started by Fredsimm, Jul 26, 2017.
  1. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    just signed up. My daughter bought an 09 and my wife had to have a Prius. I found and bought a mint condition 07 with 150k. I'm averaging 45.5 mpg overall and love this car. I've checked all that I can check so far. Oil clean, all fluids normal, no cel codes. Is there anything I should check? I read that I should clean the battery fan. Any advice?
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome to the site. Register the VINs at http://www.toyota.com/owners so you can review dealer service history and recall status. Enjoy.
    RCO likes this.
    52,927
    congrats and welcome!
    worth checking the fan and intake grille, since you don't know the history. maybe change the tranny fluid, check/clean/replace air and cabin filters, and 12v health/age. did you get two fobs? remove the metal keys and unlock the mechanical door lock before you have to. also, find the jump point under the hood, and emergency hatch release. check the spare tyre pressure.
    all the best!(y)
    WilDavis and RCO like this.
  4. Fredsimm
    188
    117
    Tupelo MS
    Thanks for the info. I was thinking about the tranny fluid. You just confirmed it. Only came with one smartfob. Is that a bad thing?
  5. bisco
    52,927
    only if you lose it. making one without having one is a lot more expensive.
    RCO likes this.
  6. Fredsimm
    188
    117
    Tupelo MS
    If I buy another fob, can I program the fob myself or does it require a dealer.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    RCO likes this.
  8. Fredsimm
    188
    117
    Tupelo MS
    Also, does 2nd gen prius have a high rate of tranny failures?
  9. bisco
    52,927
    no, very few, from what we've seen here.
    RCO likes this.
  10. Fredsimm
    188
    117
    Tupelo MS
    Now I'm a little worried. I've been reading about hv battery failures on this site. Some have said that remanufactured batteries may last one year if lucky. Somebody help me learn the best way to address a battery failure if it happens.
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    Welcome!
    Especially since both you and your daughter have older Prii it might be a good idea to invest in a grid charger & discharger from Hybrid Automotive. Many people here have used them to recondition their batteries and extend their battery life.
    @jeff652 is an active member here
    WilDavis, jeff652, RCO and 2 others like this.
  12. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    RCO, Raytheeagle and Prodigyplace like this.
  13. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Welcome and excellent news!
    Brake fluid - should be CLEAN, nearly clear, if not have a QUALIFIED shop perform a brake fluid flush.
    Coolant - if no record of coolant exchanges (ICE and HSD), plan on that for both.
    Transaxle fluid - Toyota has no schedule, but..... there is no such thing as lifetime lubrication.
    HVAC filter!!!!! - At LEAST every year.
    Air filter - no more than yearly or 60k, a dirty filter is actually better for your engine than a clean one!
    Park it in the shade when possible! Keep the interior temps down, high temps are the hardest thing on the HV battery other than sitting for extended periods.
    RCO likes this.
  14. Fredsimm
    188
    117
    Tupelo MS
    Thanks for the info. Much appreciated.
  15. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Prius doesn't have a tranny. It is a "Synergy Drive" patented system. Just change the fluid every 70k. Pretty much runs for a long time.
    RCO likes this.
