New owner confused as hell
Discussion in 'Gen 2 Prius Fuel Economy' started by mattleerocks, Jan 4, 2011.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    I'd remove the excess.
    Can you please answer the above? Again, also consider grille blocking.
  2. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    Great! Short trips are a killer - but still WAY better than in any other vehicle. You can get caught up in the higher FE standard the Prius sets for itself.
    Easy to fix the oil level, loosen but don't fully remove the drain plug and let a cup or so slowly drip out. Check the level and adjust until you're happy. You can probably even do it without elevating the car if you had to.
    - D
  3. mattleerocks
    mattleerocks New Member
    24
    I live in sunny southern california so cold weather is rare. Its rarely below 50 and if it is, its only in the morning
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You're definitely doing better. Short trips are indeed a mpg killer so unless your driving pattern changes you may never see 50mpg average. With summer temps you may hit high 40s which is what a lot of us average. Congrats on the change. :)
  5. fuzzy1
    10,707
    43 for just this particular tank, or for the life of the car?
  6. mattleerocks
    24
    Just this tank
  7. bac
    bac Active Member
    863
    52
    Pennsylvania
    By FAR, short trips will influence your mpg the most. However, as others have stated, this is the case with all autos.
    -Brad
  8. richard schumacher
    7,683
    1,066
    United States
    At the next oil change tell the service writer not to overfill it, and that you will check it yourself before leaving. And then do it. You can find lots of mistakes this way before they become expensive.
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Keep in mind that short trips also hurt the MPG of non-hybrid cars.
    Compare that 40+ MPG to the actual MPG of your previous car, NOT to the window sticker MPG it had, for the same driving conditions. :p
