New owner, disappointed in mpg...
Discussion in 'Gen 2 Prius Fuel Economy' started by mikesarebetter, Feb 7, 2012.
  1. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ...ethanol lowers mpg 1-2 mpg, so skip it if possible. But you are reporting an unusual fuel choices. Normally if you live in zone that requires ethanol it is in all grades. Normal Regular is 87 octane (R+M/2) but high altitude zones may have 85 instead and that is good.
  2. mikesarebetter
    mikesarebetter Junior Member
    53
    south dakota
    those are the only options i've seen in a hundred mile radius... and further sometimes.. elevation ranges from 3-4k ft in my area.
    i hate ethanol period so will never put it in anything.. but with my given choices what would be better to run.. 85 or 91? i assume the 85
  3. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    ...I believe you are indeed good with 85 but let's hear from mile-high-club. Sea level here.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    38
    Santa Fe, NM
    You could possibly benefit from running 91 vs. 85. If you have a lot of hills, then running 91 will keep the ignition from retarding as much under the load, making it more efficient. Usually the effect is marginal, making the slightly increased MPG not good enough to offset the higher cost of the fuel. On a very high mileage motor, carbon buildup causes compression ratio to increase and high octane fuel can help improve MPG there as well, for the same reason. It won't hurt anything to experiment, although there is a very slight chance that the 91 octane will lead to hard starting in very cold weather. There is an admonishment in the service manual about high octane leading to starting problems, but IMHO it is directed at 94+ usage in Canada.
  5. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    On my 2010, higher octane fuel reduced my mileage.
  6. mikesarebetter
    53
    south dakota
    Just wanted to throw an update out. After 4k miles or so of driving this last month i'm quite happy with the ol prius. my average is about 43-44, and have had quite fun watching my average show over 60mpg on some 55 mile little trips.
    The 58 mpg average i had a 30mph tailwind while doing 75.
    The 62 mpg average i was drafting a semi with speeds varying between 65-75
    all in all very happy with the car and actually can't wait to buy new tires and get these loud snow tires it came with off. ecopias or continentals will be my purchase choice
  7. litesong
    litesong Active Member
    371
    122
    Everett, WA
    Go to pure-gas.org for the 5000 gas station addresses & excellent zoomable map, selling 100% ethanol free gasoline & the few sellers in S. Dakota. Possibly you can find another station that gives you better options for octane ratings. As for me, switching to 100% pure gas raised the mpg of our 3 cars by 8%, 7-8%, & 6% & those figures were obtained including the winter. All 3 engines are smoother, quieter & need less downshifting when ascending hills.
