New owner with a few questions!
Discussion in 'Newbie Forum' started by liscifan, Oct 21, 2013.
  1. liscifan
    liscifan New Member
    Hi there, I finally belong here ;) I picked up a 2013 Winter Gray Prius Three over the weekend and loved my ride into work today! I am still learning about all the readouts from the car and am trying to change my driving style. But I had a few questions that I hope you can help me with:
    1. The car rocks for a few seconds when I push the P button after stopping. It was on level ground and I was at a complete stop. Is this normal? Should I be doing something else? My first time driving with a keyless ignition-felt weird but nice!
    2. I have the tire light on already :-( It was a cold morning here in NY and it didn't go away even after a 30mile drive. I didn't have my gauge with me so I couldn't check the pressure. This happens on cold days with our Rav4 too but it goes away when the car heats up. Can I drive with the light on till I can get the gauge from the other car? The gas stations around here don't have a gauge or have an inaccurate one.
    3. I checked with the dealer whether there was a break-in period and they said no. I tried finding it in the manual but couldn't. Did Toyota do away with that? I know to go easy on the braking. I want to make sure it is ok to go at higher speeds on the highway-traffic moves at 75 around here and I usually do 65-70 with my other car. Ofcourse, watching the mpg drop is enough of a discouragement to go above 55 but was wondering if I should play it safe for the first 600 miles(as I found listed in a older thread on here).
    4. Is there someway to find out the 'history' of the car trip reports? Like it shows you momentarily when you turn off the power button.
    I am sorry for all the questions-I tried searching but couldn't find any relevant threads. Please point me to other threads.
    I am still making my way through the manual..fell asleep with it the last two nights!!
    Thanks in advance..can't wait to discover all the secrets!
    52,854
    welcome! if you are on perfectly level ground, and have come to a complete stop, it should not rock after you press p. i usually find that it rolls a few inches forward or backward, even tho the ground seems level.
    if the tyres look okay, you can drive until you can check the pressure, one is likely a little low. pump them up a little higher than spec so a few psi drop won't set the tpms off.
    for 500 miles, i would vary my highway speeds, don't use c.c. and don't floor it. drive as fast as the limit and safely.
    no, unfotunately, a lot of us would like to have it. my wife's hycam flashes on and off so quickly after she powers down, she can't even read it, nevermind record it.
    all the best!(y)
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The parking pawl is fairly imprecise, and does have some slop. I actually just turn my Prius off, it automatically goes into P when I do.
  4. fuzzy1
    10,706
    I disagree here. The Prius parking gear/pawl mechanism has a very coarse tooth pitch. When placed in Park, the car wants to move until the pawl is centered between two teeth. That can be several inches. But the Park mechanism is strong enough to keep the wheels locked even when a tow truck drags the car, so this motion won't hurt it a bit.
    After the car moves, then there is enough springiness in all the mechanical elements to rock back and forth a few cycles. If this is a problem, then set the parking brake before taking your foot of the regular brake.
  5. fuzzy1
    10,706
    It is not possible for us to tell remotely whether or not it is safe to drive home without airing up. If the light came on only because of the cold morning temperature, it should be OK. But it also means that your tire pressure is below recommended levels even when warm, so it clearly needs more pressure for MPG and for tire life and for long term tire safety.
    But when my TPMS light turned on last winter, it was also because of a slow leak that needed repair. Lacking a gauge at work, I'd prefer checking all tires visually and by feel. If any tire feels lower than the others, I'd add some air at the first available station even without a known accurate gauge, just to make sure it doesn't get destroyed on the way home.
    This is a bit of a family sore point. Long ago, when the spouse's car was found to have a low leaky tire, I pumped it up and told her to go have it fixed. Then I kept re-pumping and re-nagging every other day until she finally got around to getting it fixed. By then, the tire was damaged far beyond repair, and had to be replaced. Long before that, mom tried to drive home on a visually low tire. It didn't make it, she had to walk anyway, and the tire was no longer repairable.
  6. liscifan
    liscifan New Member
    Thank you, bisco, JimboPalmer and fuzzy for sharing your opinions. Interesting to learn about a parking pawl. Do you use the parking brake every time you stop the car? With the hand operated ones, it is almost second nature to pull it up-will have to remember to put the foot brake on.
    I will check the tires-couldn't spot any difference visually in the morning. It won't hurt to put some air in it anyway. I am hoping there isn't something wrong with the tires..that will be terrible.
    One more question. This is my first hybrid so pardon me if it is standard operating procedure-but I feel like I have to press down on the accelerator hard to get the car moving from a stop. Is this normal-just something I have to get used to? It doesn't 'jump' like normal cars do if floored but you can still hear the engine exert itself. That can't be good in the break-in period. I have to go through 28 or so lights in a 10 mile stretch and I catch at least 4-5 on a good day. I guess I should just stick to the slow lane for now.
    Thank you all!
  7. fuzzy1
    10,706
    This is probably just a different touch-and-feel issue. The 'jump' on the other cars is usually an intentional part of the user interface design, to make the car feel more powerful. I personally dislike it.
    To some extent, you can tune this feel by playing with PWR / ECO / Normal, and selecting the mode that feels best.
  8. bisco
    52,854
    i never use the parking brake when i stop the car. if parking on a slope, i always use it. foot brake, parking brake, park button, power button.
  9. liscifan
    liscifan New Member
    Thanks fuzzy and bisco. Hubby checked the tires and they were all low! So he filled it up and now the light is gone. Will check tom morning if the cold still affects it.
    I agree the acceleration issue might also be becoz I am used to the V6 on our Rav4. The Prius felt better on the drive back so just takes some getting used to.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and enjoy the ride! Mine also rocks. :)
  11. fuzzy1
    10,706
    If he pumped them up while the tires were still warm from the drive home, then you will likely find the pressure down slightly in the morning. If so, just top them off again. Then when seasonal temperatures fall even more, check and re-top again.
    If he pumped only to the door sticker recommendation (35 front, 33 rear for the regular 15" wheels), then note that many of us use higher pressures for better MPG. But that is a matter of personal preference, some drivers don't like the somewhat harsher ride.
    I ran into the opposite problem when driving someone else's V6 Highlander this week, and hit the gas too hard several times before retraining my foot.
    Do try the PWR mode to see if it makes the car's takeoff feel more familiar. If so, then you will have the answer. Then you can choose to keep PWR or go to either of the more relaxed modes.[/quote]
  12. RRxing
    RRxing Senior Member
    2,563
    1,842
    NEPA
    Don't forget to reset the TPMS button underneath the steering column after putting air in the tires. Just hold it in until the TPMS light flashes, then goes out.
  13. liscifan
    liscifan New Member
    I was reading about the TPMS sensor earlier-now I just need to find it! I came across the maximizing mpg video and got 62.5mpg on the way back! Woohoo!
  14. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Welcome to the forum and congrats!
  15. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    If above does not fix TPMS take it to dealer if that does not work get black duct tape to block the flashing light. You'll need the tape if you go and get non TPMS stems with your winter tires and wheels. Try to run 2-4 lbs more of air presure in front tires due to over steer issue when car is loaded up. Most run 40f-38r. I run 42f-40r on all 6 sets of tires.
