new owner with questions
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by hanshinji, May 16, 2014.
  1. hanshinji
    hanshinji New Member
    25
    2014 Prius Plug-in
    hello. i just bought a new 2014 PIP base.
    surprisingly many things are not intuitive.
    dealer has set a destination on navigation and i can't seem to find a way to cancel the route. it always directs me to set destination. how do i cancel the current route?
    i'm also having difficulty changing the calendar date. c'mon, how difficult should that be? it took me a while to change the clock (let alone, finding where the setting is).
    i bought PIP to get a green sticker but looks like all 40k stickers are gone now. tough luck for me as i have a long daily commute. do we know if more stickers will be available? i did some research and it looks like a bill was killed recently. sigh.
  2. JC91006
    16,937
    8,647
    You'll probably have better luck driving the car back to the dealer and asking your sales person / service department to show you all the functions. It can be done in this forum, but it's no different than reading your owners manual.
  3. GregP507
    GregP507 Senior Member
    3,002
    481
    It's not easy to cancel an active route. You have to go into several levels of options in the destination menu.
  4. Kurt Weiske
    Kurt Weiske Active Member
    178
    131
    To change the date, go into the settings menu from the display in the dash - it's covered in the quick start guide.
    The guide to the audio/display system is thicker than the manual to my most recent digital camera purchase. :)
  5. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    While the map is displaying, press Route. Then "Cancel Destination." Confirm and you're done.
  6. bisco
    52,877
    welcome to priuschat, all the best with your new pip!(y)
  7. Kurt Weiske
    178
    131
    That would be a great voice command to have.
    "STOP TELLING ME WHERE TO GO"
    LisaMcC likes this.
  8. GregP507
    3,002
    481
    I believe you can cancel navigation that with voice commands, but I haven't tried it.
  9. JC91006
    16,937
    8,647
    you can just say "cancel guidance" and it turns it off.
    rxlawdude likes this.
  10. hanshinji
    25
    2014 Prius Plug-in
    thanks guys. i will try that. but c'mon, canceling current route should be easy.
    i did google my questions and glimpsed through manuals with not much luck. anyway, i will give it a shot.
    i did get to calendar edit page but then i was stuck from there not knowing how to change dates. looks like i have to use trip and disp button
  11. dubchun
    dubchun New Member
    2014 Prius Plug-in
    While you are on Navigation screen (map), tap on options, then tap on stop guidance. That will do it.
  12. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    If I remember correctly, if you want to set the year you have to fast forward through the month mode - running through 12 months sets you into the next year, etc.
  13. -Rozi-
    -Rozi- Member
    134
    60
    Slovenia, E.U.
    2014 Prius Plug-in
    Pitty, PiP doesn't pick up date and time from built-in GPS receiver. :(
