New owner with serious repair cost concerns for the future
Discussion in 'Gen 3 Prius Technical Discussion' started by VoicesInMyHead, Apr 20, 2011.
  1. VoicesInMyHead
    VoicesInMyHead New Member
    52
    Georgia, US
    Being a new Prius owner and only 1000 miles into my warranty, this doesn't immediately affect me. But, after reading some of the repair costs on some items like brake systems and inverters and such, multi-thousand dollar repair bills scare the snot out of me.
    Yeah, it's a Toyota, and with any luck, their historical reliability will apply to this car, too. But, when something goes wrong, it seems to REALLY add up fast.
    Am I just being paranoid?
  2. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    If you are really that concerned, you always have the option of purchasing an extended warranty. You can get a great (7 yr/100K) Genuine Toyota Platinum Warranty through Prius Chat (Search Discounted Extended Warranty) for a very fair price. And, there's no rush, as long as you get the extended warranty before your factory bumper-to-bumper warranty expires (3 yrs/36K miles) you'll be fine. So, set a little aside each month and when your at 35 months or 35K miles give Troy (TOG) a call and get the extended warranty. Or, just keep putting away a little each month and use that if you ever need it!
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Did you lose sleep for years over the possibility of a multi-thousand dollar transmission repair bill for your other cars ?
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    For any part that could fail on the Prius, there is an equally expensive part that could fail on a non-hybrid. Thankfully the Prius is extremely reliable.
    Lkie with any vehicle, do your research on the failed part and you can save a lot of money vs. dropping it off at a dealer and giving them a blank check. :)
  5. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Nice screenname.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    yes
  7. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    You skipped the opening bars.
    In order to get to the failed part, a $250 (!!) diagnosis/inspection fee is required at the dealership unless you can read the flashing lights and decode their meanings.
  8. SageBrush
    11,627
    2,530
    Southwest Colorado
    As usual tp, you start with one grain of truth and add 99 grains of BS or spin.
    -- The $250 fee is far from universal. I usually hear $100-$150
    -- Many repairs do not require codes to figure out
    -- DTCs can be pulled at home or an auto parts store, and advice sought here for diagnosis and repair.
    -- And lastly, diagnostic fees are not exactly unheard of in conventional cars.
  9. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    Once you're old enough to drive you'll find out that all dealerships (regardless of brand) charge this kind of money to look at a car. Independent mechanics charge a lot less, or sometimes do diagnosis/read codes for free (great way to get you in the door).
    My personal experience is that my prius has covered 30k, and needed oil and petrol, and an occasional wash. My GM Vauxhall Vectra covered 35k from brand new, needed two new fuel pumps, two fuel regulators, a new head unit, two new door mirrors, a new drivers door module and a new wiper motor.
    Even if at year 10 i need a new HV battery or transaxle i will still be ahead of the game with the fuel pumps, clutch, gearbox, brakes and who knows what else in the GM vehicle.
  10. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The standard diagnostic charge in NY and CA for independent issues looks like $250. I would get very upset if my Accord required such a high diagnostic fee.
    http://priuschat.com/forums/gen-iii...ailure-my-way-home-coachella.html#post1309032
    http://priuschat.com/forums/gen-ii-...8-prius-red-triangle-light-3.html#post1309573
  11. Flaninacupboard
    1,297
    213
    Midlands - UK
    No, not paranoid, but possibly not assessing the risk correctly. In my day job we do FMEA (Failure Mode Affects Analysis) which involves a risk level and a frequency. Something may be high risk, but low frequency (such as a prius transaxle failure) and that may or may not be a bigger problem than something medium risk with high frequency (transmission failure in a regular car). It's all about the probability and your ability to deal with the failure effects. do you always have $1000 kicking about to cover a transmission rebuild? fine, you can cope with the risk. could you have $2k-$3k available in the unlikely event of a transaxle failure? if so, you can cope with the risk. (there's then a whole other topic about whether you should leave that money available or invest it)
  12. SageBrush
    11,627
    2,530
    Southwest Colorado
    Then add disappointment to your personal problem list
    Hondacare Question: Diagnostic Fee - Honda Odyssey Forum : Odyssey Minivan Forums
    http://www.hondacarforum.com/honda-technical/53362-97-honda-accord-check-engine-light.html
  13. Flaninacupboard
    1,297
    213
    Midlands - UK
    2 people like this.
  14. SageBrush
    11,627
    2,530
    Southwest Colorado
    ^^ Am I ?
    I only meant to point out that Honda also charges diagnostic fees in the Los Angeles area.
    Two quick googles found Toyota dealers charging $110 - $130.
  15. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    If the diagnostic process is strictly electronic and you have any common sense at all you should be able to easily negotiate out of the diagnostic fee. That is of course if your dealing with people who also have common sense.
    The deal I had with previous honda dealer was is if the mechanic spent more than 30 minutes on the computer diagnostics he can charge me the hourly rate. 30 minutes is just about $48... I had my Civic in probably 6 or seven times while I owned it and never got charged a diagnostic fee.
    My kids Subaru, I had to go to three places before I got the same deal.
    We'll see what happens when my Prius has to go in with a problem.
  16. john1701a
    john1701a Prius Guru
    12,749
    5,244
    57
    Ask yourself how many silent owners there are for every vocal one. The internet tends to amplify significantly. Remember, there are now over 1,000,000 Prius owners in the U.S. now.
    I myself have surpassed the bumper-to-bumper warranty period 3 times now with 3 different Prius over the past 10.5 years of ownership. Never have I even considered the purchase of an extended warranty. The tech has proven more reliable than traditional vehicles I've owned in the past.
    2 people like this.
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Agreed w/Sagebrush. Although my Prius has not been problem free, I have NEVER paid $250 for diagnostics for any problem under or out of warranty. IIRC, I've never had to have the dealer read any DTCs off my car. I can't remember paying ANY money for diagnosing problems while I was under warranty.
    I've had my local dealer try to diagnose and fix a horrible noise and a squeal 2x, while out of warranty and IIRC, they charged me only for ~30 mins of labor each time.
    OP, pay no attention to tpfun, our non-Prius and non-hybrid owner resident troll. http://priuschat.com/forums/newbie-...onsidering-prius-iv-2011-a-2.html#post1291647 and http://priuschat.com/forums/honda-hybrids/86559-civic-hybrid-why-buy-one-3.html#post1302157 are pretty accurate descriptions of his behavior.
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    As you read those horror stories, notice how many involve using jumper cables badly?
    One level of paranoia would replace the 12 volt battery every 4 years.
    I bought auto polarity cables, the more paranoid would get a AAA card.
    Universal - Garage Pro Jumper Cables
  19. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
  20. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    You are one tough negotiator.
    I am surprised they are willing to deal. Are you a regular customer ?
    I guess lesson one is never have a car towed to a dealer unless it's under warranty.
