New owner
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JEP, Jan 3, 2014.
  1. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    Just to say hello.
    Yesterday I ordered a new PiP. Delivery in a few weeks.
    After my test drive of the PiP my Avensis D-Cat D4D really felt like an old tractor with all the vibration and sounds from the engine.
    Really looking forward to this new car.
    52,878
    congrats, welcome to the club! i'm sure you'll love it like i do, what is your commute like and how often can you plug in? all the best!(y)
  3. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Jeb. Welcome to the club, hope you enjoy it. Where are you located?
  4. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    Thanks!
    Mostly around town within the Ev-range. Will plug in whenever possible.
    A few longer trips once a week, around 150kilometers and occasionally 500-600km's
    I think Toyota's efficient hybrid technology will be the optimal choice here.
    The Ampera/Volt seams to have rather high consumption on longer trips using the gas engine for generating electricity. The PiP really shines here.
    usbseawolf2000 and giora like this.
  5. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    Sweden. We have the winter season here so i know the range will suffer and the gas consumption go up also for generating cabin heat.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    welcome aboard and enjoy the ride!
  7. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Jeb same here in Nj USA it was 10 degrees F with 6 inches of snow.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    You surely did your homework before buying:)
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Well researched / educated PiP owner. Welcome!
    markabele likes this.
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    JEP
    What is the price difference in Sweden between the PIP and the Ampera/Volt?
    Is there any government/local incentive to each of them?
  11. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    If you will be taking a lot of short trips, you may want to look into "installing" an electric cabin heater to preheat the car so you can use EV mode without the engine running. They aren't available as an option, but a small ceramic disk type heater (the kind that doesn't glow red hot) should work; the hardest part is routing the cord into the car.
  12. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Are you nuts, use the ice that's what it's there for!
  13. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    PiP has a robust cabin heater that is powered by an on-board fuel. Use it because you paid for it.
  14. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    No, I'm not "nuts" and I also don't believe in using a four cylinder gasoline engine as a cabin heater for a three mile trip. It doesn't make sense to freeze on longer EV trips, but if you can be comfortable by preheating the cabin before leaving, and do it safely, why not? Lasko makes a 200 watt compact ceramic heater. Personally, I'd use a 750 watt ceramic disk heater if I used the PIP regularly in Winter. (I drive a Leaf.)
    retired4999 likes this.
  15. JEP
    JEP Junior Member
    Sweden
    2013 Prius Plug-in
    Thanks for all replies!
    Yes, my PiP will have a pre heater installed by Toyota on delivery. I also looked at the remote engine start but my local Toyota dealer hadn't heard of it earlier. They found it when I gave them the part number and PDF with install instructions but couldn't get a price so I decided to go without it. Maybe order it from priuschat later on if I need it. In any way I need to unplug the charger cable to get the remote starter to work.
    Also looking forward to test the LED headlights. Never tried LED's earlier.
  16. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    So there is a pre-heater available from Toyota? Details, please!
  17. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    I would love to drive a Leaf ! Show me one that gets a guaranteed 100 mile minimum range for what I paid for my PIP and I would get it!
  18. bisco
    52,878
    block heater.
  19. bisco
    52,878
    this has been tried by a few members with no success.
  20. bisco
    52,878
    i don't use the ice either, if i can make it on ev. my wife thinks i'm nuts!:eek: i have to admit, with temps around zero the last few days, i haven't bothered to go anywhere, it's just not appealing.
    Michael33 likes this.
